Tom's Hardware > Forum > Storage > General Storage > Serious problem..hard drive
Forum Storage : General Storage - Serious problem..hard drive
I tried to upgrade the hard drive on my Sony vaio sr laptop, i installed the new hard drive but my computer would not recognize it, so i put my original hard drive back in and now the laptop does not recognize it too. The connections look perfectly fine. what did i do, and is there any way to fix it? thanks
Sponsored Links
You might have to enable the hard disk in your BIOS. Can you access your laptop's BIOS?
Reply to le13enforce
I know it may sound odd but enable sata and make sure that the harddrive is not set as slave. If both fail I would rma it.
Reply to manicmalki
There are 480 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
