Tom's Hardware Forums » CPU & Components » CPUs » help with new build!
Add a reply
 Word :   Username :
Bottom
Author
 Thread : help with new build!
"Couldnt think of one"
Profile: old hand
More Information
for some reason when i boot my computer and its loading vista just before the vista display appears a blue screen appears and then my computer restarts keeps happening over and over. This is my new build but the hardrive is for my previous machine.
spec
q6600
msi p6n diamond
4gig ocz ram
9800gtx antec earthwatt 500.
intel core 2 quad q6600 @3.2ghz msi p6n diamond (X-FI sound) 4gig of OCZ oc 900mhz 2 Nvidia gtx 260 sli @ 710/1230 Lite-On Blue-ray 500gb Antec Earthwatt 500 Windows vista home prem 64-bit
22" lcd acer monitor
Logitech X-540 5.1 Speaker System
Related Pr oduct
Profile: old hand
More Information
this is odd, is your ram bargain ram? sound like it could eb a memory leak
Profile: old hand
More Information
nvm all i did was re install vista everything is fine now thanks tho.
Profile: enthusiast
More Information
Sounds like it was a driver thing. I had a similar issue when i somehow managed to install the ATI Tool driver twice. I still don't know how it happened, bit nonetheless it was a BSOD every time i tried to boot it.
I had to boot in safe mode and uninstall it.
http://valid.x86-secret.com/cache/banner/354584.png
http://farm4.static.flickr.com/3261/2577559697_bdb9aec12f_o.png
http://farm4.static.flickr.com/3098/2577559521_edb3ac038e_o.png14591 3DMark06 6210/6104/4507 Vista 64bit
Profile: Forum Veteran
More Information
Not really a driver thing, but if you make a major change to the hardware (such as a new motherboard), you need to reinstall Windows so it knows which hardware it is dealing with at startup. The OP's problem was that Windows still thought he had his old motherboard.
e2160@3GHz: OCing my way to Ubuntuland!
Add a reply
Google Ads
