Hey guys im looking for a good tv tuner for my acer 22inc monitor resolution at 1680x1050 which one would you recommend. Is there a way i can connect my wii with the tuner so i can play on my monitor?
And if u can find a tuner under 100$ that would be great.
Thanks.
------------------------------intel core 2 quad q6600 @3.2ghz msi p6n diamond (X-FI Extreme sound) 6gig of OCZ+CoRSAIR oc 900mhz Nvidia gtx 260 sli @ 730/1465/1250
Lite-On Blue-ray Western Digital 7200rpm 500gb Antec 500 Earthwatt Window vista 64-bit
I have an ATI 650 PCIE TV Tuner....Its a lot better than Hauppage. I trid different Tuner cards on my PC(ATI, Aver Media, Happauge, Pinnacle...etc). I cycled to each brands and settled with ATI650PCIE.
No card is prefect it will have issues left and right. For my need ATI650 ...HD Tuner video quality is very close the quality of my TV Digital Tuner.
------------------------------Q6600: Maximus Formula: Zalman 9700LED8GByte: Crucial Ballistics 4-4-4-12: PC6400; Vista Ultimate-64BFG XOC 4890; Disp: 70 Inch HDTV: Hauppage 2250 HDTV Tuner1.4TByte: 2x750Gbyte; RAID0; Case: Antec 900: PS:Antec Quatro 850
Reply to leon2006
A have the ATI as well, and hauppage pvr150 analog, the ATI does great for over the air, but on 22 inch monitors i find anything but digital looks like garbage.
------------------------------If you don't know what OS/2 is, you don't understand.
Reply to rockbyter
