Hi, My PC is about two years old. I want to upgrade the Sapphire HD5670 1GB DDR5 video card I installed about eighteen months ago. However, before upgrading the video card I need to upgrade the ATX size PSU, The size of the new PSU needs to be about H3 3/8" x W5 7/8" L5 1/2") otherwise it won't fit in the small ATX case. Ideally I'd like an ATX 450watt modular bronze rated, quiet. The Sapphire HD 6770 Vapor-X requires 450watt, one 75 Watt 6-pin PCI Express power connector. The Intel MicroATX DH55TC needs a 24pin power connector. At this time I'm not using any additional cards. The new PSU will replace a generic 350watt (400watts peak) Delta PSU
So far, it seems ANTEC as some PSUs that'll work but they aren't modular. The case is so small modular PSU will work best w/o impeding air flow.
link to antec PSU ea 450 platium
http://www.antec.com/product.php?id=704512&fid=11
antec PSU ea 500 green
http://www.antec.com/product.php?id=704485&fid=11
antec PSU
http://www.antec.com/product.php?id=2407&fid=9
None of these PSUs are modular. Recomendations for other brands welcome.
link to Sapphire Vapor-X
http://www.amazon.com/Sapphire-Vapor-X-DisplayPort-PCI-Express-100328VXL/dp/B0056J9J1G/ref=sr_1_1?ie=UTF8&qid=1339716953&sr=8-1&keywords=sapphire+hd+6770
ZT Sysytems 7391Mi
Intel i7 Processor 870 (2.93GHz)
Intel DH55TC motherboard
8GB DDR3RAM
sata II 1.5TB HDD
ati radeon 5670 1gb video card
Win7 premium 64bit
Thanks
antec PSU
ZT Sysytems 7391Mi
8GB DDR3RAM
sata II 1.5TB HDD
Win7 premium 64bit
Thanks
