Charging battery
Hello,
When charging battery, will the blinking red light turn to green when it's fully charged?
4 answers Last reply
More about charging battery
  1. It should, and this should be in the Laptop forums. Unless you mean some other blinking red light that's maybe outside on the street, then you treat like a Stop sign and it will probalby not change when your laptop is charged.
  2. My problem has been solved. It just took longer than I expected to charge up.
  3. 9 Days according to the post :-) That IS a long charge.
    Should take several hours to fully charge, if it's fully empty, you may not get the green light for a while.
  4. No, it only took overnight, plus half a day, guess it was discharged more than I thought.
    Thanks again, problem solved, I just have to remember to make sure it's charged up more often, instead of waiting 3 months. LOL!! I don't use my laptop unless I go out of town for more than one day.
    Loretta
Battery Light Green Windows XP
