Problems with Gbyte DS3L after build completed
Last response: in Systems
Specs of PC:
e2180
gigabyte ds3l
2 GB crucial Ballistix
EVGA 7800GT
Corsair 550w VX
AC Freezer 7 Pro
The sytem boots fine and runs fine at stock, however when I go into BIOS to overclock the cpu the comp just shuts off when I try to save my o/c and won't restart unless I flick the switch of the PSU. All I changed in bios is the cpu frequency. It is set at 200 stock and it shuts off at anything above that(tried everything from 201-260). I bought this CPU to O/c it and get good BFYB performace. Any ideas and suggestions would be much appreciated
How are you overclocking? Need more info on what all your doing in the bios.
Palit 8800GT Super 1GB 700/950 SLI
E6600 @ 3.6 1.47v
Asus P5N-e SLI @ 400
GSkill 2x1Gb DDR800
WD 74GB Raptor
Audigy ZS
Hiper TypeR 580 PSU
Antec 900 v.2
LG L226WTY-BF
3Dmark06 16200
Make sure you ctrl @ F1 in bios then check the ram voltage and timings. On this board it is in +.1 up to .7 and base starts at 1.8 so if that ram is 2.2 make sure to move it up to .4 then change the timings after that start changing your cpu frequency and dont forget to up the voltage on your cpu if you are going to far for stock volts.
Ask the community
