Well, I have always heard good things about Corsair, so I voted for them. I don't know much about how good multi rails are. I'd be interested to see what others say about it.
------------------------------New Build (Under Contruction): Intel Core i5 750 > Gigabyte GA-P55-UD4P > 2x2GB GSkill 1600MHz CL7 1.65V > Samsung Spinpoint F3 1TB > Antec 300 Illusion > Asus 4850 512MB w/AM Cooler > Corsair 650HX > Hyper 212 Plus > See other Builds in Member Config
Reply to EXT64
Seasonic
Corsair (the HX series is made by Seasonic)
PC Power & Cooling (Seasonic makes some of their PSUs like the Silencer 610 and lower)
2nd that!! You could even go with the Corsair vx550w PSU that has 41A on the 12V rail, which would be plenty for your rig. I'd go with Seasonic/Corsair/PCP&C/Antec brands of PSU's. At least 450w or more for that setup. 500w+ if you want some room for OC'ing and other upgrades.
I know that the VX is made by Seasonic and that makes it good, but what about the TX? Are they crappy? Or are the TX series still quality PSU's as well?
Also, thanks for the input on the overkill amount of wattage. However I do want room for another 2GB of RAM down the road and an additional 9800GTX, plus some overclocking potential.
Also, please try to restrict suggestions to only the PSU's I have given as options (for various reasons that are kinda complicated).
TX 650 = Seasonic
TX 750 = CWT
------------------------------q9650 @ 4.050 | Asus Rampage Formula | 2x2 & 2x1 Corsair Dominators | WD Black 640 x2
EVGA GTX260 Core216 @ 686/1479/1103 | Antec TPN 750
Reply to Delluser1
According to Tom's review on the 9800GTX, a single card will take up around 265 at load. Theoretically, having two in SLI would then use up around 530W out of the available 624W on the 650TX's 12V rail, leaving 94W for anything else.
I would expect the PSU to hold up okay while doing light jobs, but I wouldn't be surprised if it starts giving problems when it's getting stressed out. In my opinion, upgrading towards at least the Corsair 750TX, if not the PC P&C 750W Silencer, would be money well spent.
Actually that 265 refers the the whole system load at that point.. the GTX itself only pulls ~150. Any 600+ W PS is plenty of power.. even for an SLi system generally
I went with the Toughpower 750W over the Corsair myself.
They're roughly equivalent - I found reviews of both on JonnyGuru's site and they were rated equivlently there. I posted on the forums there and the reviewers felt them to be about the same. I went with the Toughpower for two reasons: the review showed slightly less ripple on the 12V rail and - maybe more importantly to me - I got a great price on it.
Either one would be good enough/more then enough - go for whatever you can get the best price on.
You could get away with less, as posted above, the VX550 is enough for your system and CWT makes their own industrial grade PSUs as well as contracted stuff for other companies, both good and bad companies, some CWT PSUs are pretty weak, others are great, the Corsairs are the latter.
