Fan Controller Installation Help
Forum CPU & Components : Power Supplies, PC Cases & Case Mods - Fan Controller Installation Help
I have the following fans
4 side
1 rear
1 front
1 top
My fan sunbeam rheobus extreme 6 fan controller will be running 6 of these
1) what fan should i not connect to this fan controller?
2) some of the power cords for the fans i installed are too short to reach the fan controller, the controller came with a few extension cords, but i'm confused on why one of them splits from one to two connectors...
the manual doesnt really tell me what extension cords are what so can anyone help ? i figured out a couple of them but just double check i have it right...
Power Wire
[#ff0e00] 4P - 2P)
3P to 3P wire (x2)
Black & red wires
3P to 4P wire (x2)
black and yellow wires with two to blanks on 4P
RPM Signal Wire for MB (x2)
[/#ff0e00]yellow, black, red wire for 3P and black, yellow for 3P and one that has 2 black, 2 yellow, 1 red)[#ff0e00]
for the RPM Signal wire what end is the extension and what one goes into motherboard?
does anyone have a link to an install guide/video?
note: i'm a new builder so explain it as detailed as possible
Sponsored Links
As for question 1, i would personally 'bodge' the rear an top fan together. Connect the Rear to the bottom of the tops wires then plug that into the controller. Both will be controlled as one:).
Question 2 i think can be answered by saying you can link your fans power by tapping off the HDD or Optical drives 4 pin molex.
Message edited by closed_deal on 05-07-2008 at 02:28:57 AM
Reply to closed_deal
Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > Fan Controller Installation Help
There are 715 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
