Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > RAIDMAX HYBRID 530w modular ? OR Thermaltake Purepower 500w?
Forum CPU & Components : Power Supplies, PC Cases & Case Mods - RAIDMAX HYBRID 530w modular ? OR Thermaltake Purepower 500w?
im trying to keep my budget at $900 but i need to know if that raidmax is a good psu. im trying to save money too.
WHICH ONE OF THESE SHOULD I GET?
Thermal take: http://www.newegg.com/product/prod [...] 6817153052
Raidmax: http://www.newegg.com/Product/Prod [...] 6817152028
IF you got one thats better and thats the same price or cheaper give me the link. THANKS
SPECS:
CASE: COOLER MASTER Elite 330
MOBO: GIGABYTE GA-P35-DS3L LGA 775 Intel P35
VGA: EVGA 512-P3-N841-AR GeForce 8800GTS (G92) 512MB
RAM: Crucial Ballistix Tracer 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800
HARD DRIVE: Western Digital Caviar SE16 WD3200AAKS 320GB 7200 RPM SATA 3.0Gb/s
cd/dvd: ASUS 20X DVD±R DVD Burner with LightScribe Black SATA
OS: OEM Microsoft Windows Vista 32bit home premium
CPU COOLER: ZALMAN 9500A 92mm 2 Ball CPU Cooler
Sponsored Links
Id go with the Thermaltake, youll find generally they have a better reputation
------------------------------ "This thread made me strap on my lolerskates and head for my roflcopter."
Reply to chookman
- 0 +
The Raidmax has better 12v rail ratings, and by specs, is a stronger psu. A lot of people say it's a bad brand though. Higher specs won't do you any good if the thing is defective. I have no experience with either, and can't say. :p
------------------------------ Q6600@3.6ghz, GA-EX38-DS4 motherboard, 8gb 800mhz ddr2 4-3-3-12, 8800GTS(g92)@780mhz, 1TB + 1.5TB hdds, 850watt psu
Reply to dagger
- 0 +
Notice the 5 egg rating on that Thermaltake.
I think my work here is done...
------------------------------ http://farm4.static.flickr.com/3073/2578392638_2827857d10_o.png
Reply to B-Unit
Raidmax has been working for almost a year for me now the hybrid one anyways. Powers my q6600 my recent 4850 and 5 fans with 1 dvd drive 1 cdrom drive and 2 hard drives
Reply to perez8434
There are 1253 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
