For some users, computer designs can't be small and quiet enough. Mini-box.com has begun offering what it claims to be the world's smallest ATX compliant power supply that uses a single 12 volt power source and puts out 120 watts. Read more
Thermaltake now offers a high performance power supply for users that just can't get enough power. The new model belonging to the Toughpower line provides up to 2 Kilowatts of power. Live demonstrations are given at the company's CeBIT stand Read more
OCZ Technology Group has introduced a new modular power supply with a sustained output of 600 watts. The PSU will hopefully lessen cable clutter because only the necessary power cables need to be attached. The titanium mirrored case comes with two PCI-Express cables and a 4/8 pin CPU auxiliary fan connector. Read more
Thermaltake announced recently that three new products in its PC case, power supply and cooling system lineups have recently received Nvidia ESA (enthusiast system architecture) hardware platform certification from Nvidia. Read more
Three dramatically different builds face off in a show of performance, defining the real value of each. Our mainstream system is designed to meet the needs of most users. Who should spend more and who can live with less? Read more
For the second to last day of our System Builder Marathon series, we add a $500 gaming PC to the mix. It's not going to be as quick as our other two builds, but we think Paul was able to get some serious value from this thing. Read more
We're following up yesterday's $4,500 behemoth with a more affordable $1,500 mid-range build. Let's see what sort of performance (and overclocking headroom) you can get when you spend one third of the money. Read more
This month's System Builder Marathon spreads the system prices out even further to $4,500, $1,500, and $500. Is today’s $4,500 system really worth three times as much as an upper-mainstream performance machine? Read more
Tom's Hardware Forums »
CPU & Components
Power Supplies, PC Cases & Case Mods »
Is my new power supply DOA?
| Bottom | |
| Author |
Thread : Is my new power supply DOA?
Profile: stranger
More Information
Hello,
Related Product
Profile: journeyman
More Information
There might be a button near the power cable at the back of the case . Switch that and it will essentially turn it on. If not, make sure all the cables are plugged in and all the socket plugs in also.
Profile: enthusiast
More Information
Did you turn the PSU on? I've done that a couple times myself, resulting in a brief moment of panic before realizing what i forgot.
14591 3DMark06 6210/6104/4507 Vista 64bit |
Profile: stranger
More Information
I turned on the switch on the power supply, so that isn't the problem. I'm at work right now so I can't check, but maybe it's set on 220V? I honestly didn't check when I installed it.
Reformulated with 20 percent less ahole !
Profile: nimble knuckle
More Information
what kind of hardware are you running ? Some power supplies refuse to turn on if there is not enough load (power draw) from the system. Also, some motherboards don't give certain power supplies the proper signal to wake up, so it would help if you listed your other hardware. --------------- X2 5400+, Biostar TA780G M2+ MATX, 2 gig mushkin, 8800gts 512 , CM 532, Kingwin 450w ATX 2.2 "Now if the 4870x2 was actually notably faster than the 280 for about the same price, then I might even take a chance on it. However, that won't be the case." |
More Information
http://www.jonnyguru.com/modules.p [...] ndar_id=16
Profile: old hand
More Information
There's a section on troubleshooting PSU's here that is useful if you have or can borrow a digital multimeter:
Profile: addict
More Information
make sure you got power in the wall socket, and check with a ground fault checker. Sometimes it can be the wall socket itself. |
Profile: old hand
More Information
are the frontpanel power and reset buttons connected to the right pins on the mobo, maybe you got those mixed up.. |
Profile: stranger
More Information
Thanks for the help everyone. I did everything everyone suggested and still nothing when I turn on the power. I tried the paperclip trick and the PSU is working that way but when I plug it in I still get nothing.
Profile: enthusiast
More Information
What are your specs? Are both the 24-pin motherboard AND 4-pin CPU power connectors plugged in to your motherboard? Did you use metal standoffs between the motherboard and the case to prevent a short? |
Profile: stranger
More Information
Specs.
More Information
Take everything out of the case and try it. --------------- X2 5400+, Biostar TA780G M2+ MATX, 2 gig mushkin, 8800gts 512 , CM 532, Kingwin 450w ATX 2.2 "Now if the 4870x2 was actually notably faster than the 280 for about the same price, then I might even take a chance on it. However, that won't be the case." |
Profile: enthusiast
More Information
Disconnect the hard drive, dvd burner, and try using only one stick of RAM. If still nothing, remove the video card and see if you get any beeps when you turn the system on. Don't get disheartened, this happens to experienced builders too! |
Profile: enthusiast
More Information
Good call royalcrown, that would effectively rule out a short. Make sure you set the motherboard on something non-conductive like the anti-static bag the board came in. |
Profile: stranger
More Information
