Tom's Hardware Forums » Graphic & Displays » Graphics Cards » Will a 9600GT fit my motherboard?
Add a reply
 Word :   Username :
Bottom
Author
 Thread : Will a 9600GT fit my motherboard?
Profile: member
More Information
My friend wants to put a 9600GT vid card in his PCie x16 slot. However the box of the video card says you need a PCie 2 x16 slot. Is there a difference? What is the difference? Will it work?
Many thanks,
P4 3.0Ghz HT Prescott
2Gb DDR400
Gainward Bliss 7800GS+ 512Mb Golden Sample AGP
Creative X-FI Pro gamer
Related Pr oduct
Profile: Honorary Poster
More Information
It will work fine.
There was PCIe1, and now there is PCIe2.
All PCIe2 cards are backwards compatible to work with PCIe1.
Physically, the slots are exactly the same.
No worries.
Profile: member
More Information
Fantastic many thanks.
2Gb DDR400
Profile: Faithful Poster
More Information
As usual there are a few exceptions, check the internet if anyone had problems using a PCI-Express 2.0 on your motherboard.
Scruze my English!
Add a reply
Google Ads
