Tom's Hardware Forums » Homebuilt Systems » New System Build » Questions about setting up a new build
Add a reply
 Word :   Username :
Bottom
Author
 Thread : Questions about setting up a new build
Profile: stranger
More Information
I have finished assembling a new PC - Intel Quad Q9300, Abit IP35 Pro, ZeroTherm BTF90, GEIL 2x2GB DDR2800 memory, Lian Li PC-60BPlusII, Antec NeoPower 650W, EVGA 8800GTS 320MB, 2x Samsumg SATA DVD Burners. I will be moving my SATA HDDs from my current machine to this new build - 1 x 80GB, 1 x 200GB, both 7200 rpm.
I am trying to figure out the order of installing firmware, updates and software. I have taken an Acronis True Image image of my system disk from my current gig (an older IDE HDD that will not be transferred to this machine).
Should I install this image on the disk of the new build? Or do I need to have a fresh install of all software and apps (XP Pro SP2)? The image will contain drivers for the earlier AMD 64/mobo /video cards - will this create problems or can I remove/fix these after installing the image?
Should I be updating the BIOS before any software installs?
My plan is to set up a dual-boot system - Win XP Pro and Ubuntu Linux. Or alternatively Ubuntu only with Win XP running under VMWare. Any thoughts? I am not sure how well Adobe Photoshop and Premiere will work under VMWare/XP...
Any suggestions would be welcome. Once I have a system up and running, the next step will be OC it to about 3-3.5 Ghz - if anyone has done this before on this combination, please let me know the settings that you used or think will work for this setup - FSB, VCore, memory voltages, timings, etc.
Thanks
Related Pr oduct
Profile: Forum Veteran
More Information
The order doesn't matter very much. But I do this:
pre-upgrade:
research for the best bang mobo/cpu (reviews/specs/overclocks)
read through a thread or two dedicated to the mobo/cpu to know the pros & cons
download all relevant drivers & manuals to cd/dvd
take a look at the board layout
download latest stable (no beta) bios to disk
read flashing instruction
upgrade:
build the barebone with a floppy/card reader/dvd
clear cmos & load default in bios
flash the bios
restart a few times to make sure everything works
set up bios per specs of cpu/ram
put everything together in the case with side panels off
restart pc a few times
overclock
memtest
until it's stable, save settings on paper or in bios
post-upgrade:
zero-write boot sector of hdd
disconnect network
install xp
install drivers
install service packs
install apps
recall last known stable o/c settings in bios
test for stability in xp
Overclocking:
If you're experienced in o/cing & don't want to waste time, google for other's successful o/c's & settings. They usually work. Perhaps, a notch more or less in voltages. Or you can look at a guide like the one here in o/c forum & start from FSB 333, up FSB by 3-5 until windows no longer boots, either up voltages or back down the FSB by 2, test for stability in orthos x2, memtest last (loop #5 for 30 times).
Message edited by akhilles on 04-09-2008 at 02:01:18 PM
Add a reply
Google Ads
