Tom's Hardware > Forum > Homebuilt Systems > New System Build > Need help building a new system
Hello everyone. I am currently in the process of trying to put together a budget gaming system for UNDER $550. I live in Europe if that plays a part in from where the items are purchased. Here is what I will need:
MOBO - need 4 RAM slots for use of 4GB and room to upgrade to a decent CPU a year from now. I would prefer one that is capable of doing dual cards down the road but don't know how realistic that is. I have no idea which chipset is best with corresponding CPU types for my budget
CPU - Intel or AMD although I prefer Intel. I am also up for overlocking if it is safe and within the means of the hardware chosen if that makes a difference
VIDEO CARD - mostly for playing MMO's but some FPS as well. Will be used with a 17" or 19" Monitor. I can always upgrade this several months later but looking for at least a DDR3 card.
RAM - 2x1GB kit nothing larger since I plan on adding another 2x1GB kit a few months down the road when budget permits
Case/PS - PS doesn't neccessarily have to be good enough for the upgrades I would like to do in the future but rather just be good enough for this current system
HDD - nothing smaller than 500GB
I used to build computers years ago but it has been some time now and I admit I am a little out of my element and definitely need some advice from those who know far more than I. I welcome all feedback and am ready to answer any questions any of you all may have. Thanks in advance and look forward to hearing from you all! :)
Sponsored Links
where in europe? Be difficult to advise in terms of pricing and store availability if you can't mention at least the country.
Reply to amd_fanboi
If you're only going to be using a 17" or 19" monitor, don't bother with the dual video cards. Any improvement you see won't be worth the much greater price premium.
Since you're looking to upgrade the CPU in a year, I would say to get a E2160/E2180 with most likely a Gigabyte GA-P35-DS3L motherboard.
To really help you, we'd need to at least know what currency your $550 budget is in. Also, will you need to get a new OS or optical drive?
Reply to oushi
Thanks for replying and sorry for not being more specific on some things. I am living in Switzerland and the currency is swiss francs. I don't need an OS nor do I need an optical drive. When I end up going with dual video cards it will be in conjunction with something like a 32" LCD. So I would still like the capability for dual video cards later while using a budget single one now if at all possible.
I also up until just recently found what seems to be a decently priced online company that ships to where I am at.
They are at: http://www.digitec.ch/
Are the E2160/E2180 considered an Intel Core2 Duo? Would any motherboard that runs a E2160/E2180 be able to run something like a E8400 later?
I have been researching online and still am lost as to how good of a power supply I would need in all this as well. Online and locally I see Cases with 400W power supplies for pretty cheap? Is this an option until I upgrade teh CPU and video card later?
Thanks again for replying and let me know if theres anything else I need to provide to you to help you help me! :)
Reply to krane78
^ Agreed. Get E2180 OC to 3Ghz easily with a P35-DS3L any you are pretty much set until Nehalm becomes affordable ;).
If you decide to get a P35-DS3L and want help OCing checkout:
http://www.tomshardware.com/forum/ [...] w=0&nojs=0
Message edited by Shadow703793 on 04-09-2008 at 02:03:04 AM
------------------------------ http://farm3.static.flickr.com/2617/3815217176_0a5be7955d_o.gif
http://farm4.static.flickr.com/3553/3818083596_1a772f7162_o.gif
Reply to Shadow703793
Thanks for the replies, I think that I will indeed go with the P35-DS3 and the E2180 and OC it. Is there any brand name ram that is best suited for this chipset/board? Any recommendations for Corsair or Patriot? Will a 400W power supply be sufficiant to run this system now if I have just 1 HD 1 optical drive and something like an 8600GTS video card?
Reply to krane78
Ok so I think I have a finsihed build. Please any feedback would be wonderful!
MOBO: Gigabyte GA-P35-DS3, Intel P35, FSB 1333 ---> $136
http://www.digitec.ch/ProdukteDeta [...] kel=135872
CPU: Intel DUAL-Core E2180, 775P,800MHz,1MB,65nm,Fan,BOX ---> $83
http://www.stegcomputer.ch/details [...] =int-e2180
RAM: Corsair TWIN2X2048-6400C4, 2x1GB, DDR2-800, CL4, 4-4-4-12 @2.1V ---> $66
http://www.digitec.ch/ProdukteDeta [...] kel=120274
VIDEO: XpertVision GeForce 8600GTS, PCI-E, 256MB GDDR3 ---> $77
http://www.digitec.ch/ProdukteDeta [...] kel=134458
HDD: 500GB,SATA-II,WD5000AAKS, SATA-300, 7200/ 8,9ms/ 16MB ---> $100
http://www.stegcomputer.ch/details [...] -wd5000aks
DVD: Lite-On LH-20A1L, 20x DVD±RW, DL, LS, schwarz, SATA ---> $42
http://www.digitec.ch/ProdukteDeta [...] kel=147218
CASE: L-Case Duro-1, Midi-Tower, black/silver, 400Watt ---> $57
http://www.digitec.ch/ProdukteDeta [...] kel=122821
Total cost = $561 (Swiss Francs)
All items purchsed from the following 2 sites because I do not know of any better/cheaper ones that ship to Switzerland.
http://www.stegcomputer.ch/shop.asp (This one is local and online)
I used a wattage calculator from asus's website that told me with what I have chosen that the minimum recommended PSU is 350W. I do not plan on upgrading anything without also upgrading the PSU at that time.
Does this all look OK? Is everything compatible? Looking forward to hearing feedback and please keep in mind that (as far as I know) my options are a bit limited on where I can buy from and what is available to me. :)
Reply to krane78
There are 1043 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
