Tom's Hardware Forums » Homebuilt Systems » New System Build » problem with my new system
Add a reply
 Word :   Username :
Bottom
Author
 Thread : problem with my new system
Profile: stranger
More Information
Hello,
I put together a system about 6 months ago. Here are the specs:
Gigabyte n650sli motherboard
Intel E6750
MSI 8600GT 256MB
Corsair 2GB RAM
2x WD Caviar SE16 250GB hard drive
Lite-on dvd burner
Rosewill RP500-2 ATX12V v2.01 500W Power Supply
Rosewill R5604-TBK 0.8mm SECC Screw-less Dual 120mm Fans ATX Mid Tower Computer Case
Windows XP home
I didn't have any problems at first, except for some occasional lockups. For the last few months the problem has been getting worse. I would get a BSOD or lockup within 20 minutes of booting up. I did notice that if I restart my computer right after booting up, I would not get any errors. I tried updating all of my drivers, but that didn't help. Please help, any suggestions would be greatly appreciated.
Related Pr oduct
Profile: enthusiast
More Information
Check all PSU connections. Make sure all the pins are fully pushed on and not backing out of the plastic connentors. Make sure all the pins fit tight. The female connector has to be a little smaller than the male connector.
Check HSF for proper seating and attachment.
Check Ram fully seated and locked in.
Reset bios to default and retest.
Run memtest86.  free download.
Get out of here...and take your fail with you.
Profile: member
Most definitely check all of your power connectors.
He is also right about resetting the bios. Do you have any sort of overclock on the CPU?
Intel Core 2 Quad Q6600 G0 @ 2.68 GHz/1.12v (Stock cooling p'wns!) - Gigabyte GA-G31M-S2L - 4 GB A-Data DDR2 800 @ 850 MHz/5-5-5-15 - GeForce 8800 GS (EVGA 384-P3-N851-AR) @ 700/1745/2056 - ASUS Vento mini tower - Seagate 250 GB 7200.10 hdd - Razer KRAIT
Profile: newbie
More Information
Have you tried running a hard drive integrety scan?  I haven't had much luck with WD drives since the late 90s.  Now I only use hitachi desk stars.  Go to WD website and download the disk drive utilites.  Burn a bootable ISO and run the integrety test.  If it passes, it's not the Hard Drive.
Also, I don't have any experinece with Rosewill PSUs but a lot of people on the fourm bash them as unreliable.
Message edited by kwanasek on 04-11-2008 at 08:37:31 PM
Add a reply
Google Ads
