Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > Need help in choosing good case cooling fans
Forum CPU & Components : Power Supplies, PC Cases & Case Mods - Need help in choosing good case cooling fans
I Need help in choosing good case cooling fans for the CM Stacker 830.
need your recommendations
Sponsored Links
It is the mark of an educated mind to be able to entertain a thought without accepting it.
-Aristotle
Reply to ausch30
http://www.newegg.com/Product/Prod [...] 6835226013
90cfm airflow at only 18dBA noise level.
------------------------------ Q6600@3.6ghz, GA-EX38-DS4 motherboard, 8gb 800mhz ddr2 4-3-3-12, 8800GTS(g92)@780mhz, 1TB + 1.5TB hdds, 850watt psu
Reply to dagger
cant i only use 120x25 fans for the side panel of the CM stacker 830 ?
Reply to matan_levis
I would always recommend the Silverstone Suscool 121 fan. It has no flashing lights or anything like that but is very reliable and quiet.
Plus I think it looks cool. :p
Reply to theTHiiiNG
wheres the first place I should think of putting the fan at?
Side ? Bottom? top? Front?
I'm building my fist pc just to let you know
Lets say I get 4x 120mm fans, where should I put them?
I have the 832 which is pretty much the same case. I'm using 6 fans
front - in
top & back - out
two side panel toward the front of the case - in
lower side panel toward the back of the case - out
The upper side back spot is empty to fit my Ultra 120 Extreme
http://i192.photobucket.com/albums/z311/AUsch30/IMG_0135.jpg
This setup works good for me because I have a 8800GT and the two lower side fans are directly next to it so the one toward the front is sucking cool air toward it's intake and the lower rear is removing it's hot exaust.
With 4 fans I would use the front, top, back and lower front side. Keep in mind that the case is basically a big screen so be mindful of the dB level of the fans because unlike some cases with noise dampening there is nothing to quiet them down.
Message edited by ausch30 on 05-10-2008 at 05:02:43 PM
-Aristotle
Reply to ausch30
There are 1216 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
