Ive been getting a little bit stressed out with getting a new graphics card. I only have a Dell Dimension E520 with a spec of:
-Intel Core 2 CPU 6300 @ 1.86
-2046MB Ram
I am running windows Vista and only have one PCI graphics slot free. Im not sure about hardware for computers but i want a budget card for £100 less...i was going to spend more but my friends have said there is no point unless i have a decent processor (quad core) is this true?
I dont know how much power the computer has for the graphics card but any advice on this would be a great help as im a little blind in the dark at the moment.
I am not sure where the best stuff in Europe is, but if you can find a 8800GS or a 9600GT you would be rocking it. Just verify that your PSU can handle the power requirements of either of these cards. Both should be around your budget.
Yup, first make sure that you have a PCI Express slot, then start shopping for either a 9600GT or an 8800GS, both are great for the budget minded, they both have excellent performance/price ratio
------------------------------Exchange Engineer - Why is it that when DNS goes down everyone thinks it's my exchange server?
Thanks for the quick replies. Have been a big help. I will check if i have a PCI Express slot but im 99% sure i have. I web site of choice for me is scan...they have about 15 different 9600GT cards. Could anyone point one out that looks good please. The link is here
http://www.scan.co.uk/Products/Pro [...] bnails=yes
LOL, your right mousemonkey as far as his processor goes...it's a little slower but not that bad. But they would have a point if he were on a P4 1.8GHz
Before you buy, check that you have a PCI-E x16 slot. I have this feeling that you don't. I'll try to find out.
Edit: I checked. You do have a PCI-E x16 slot. Unfortunately, it looks like the case is too small for more recent cards such as the 8800 series (does anyone know if the 9600GT would fit ?) and the PSU is only 305W.
Thanks....the graphics card i have in the case at the moment still has a fair way back it can go. Although i do not know the exact meas of the cards. What would you recc with the 305w power supply ?
That's a bit tough. Cards that can play recent games well tend to consume a lot. I'd try the 9600GT or even an 8800GT, if they fit in the case, plus a new PSU. I managed to fit an OCZ StealthXStream 600W once in an HP. Measure your PSU and then we'll see what else can fit in there.
Maybe somebody who knows Dells better can tell us, does Dell still use proprietary PSUs in the E520? If it does you've got another problem. These boxes are a big pain to upgrade
No, dell doesn't use special PSUs anymore. The 305 is pretty good to, has 22A on the 12V rail. Should be enough to run a 9600GT, maybe even an 8800GT. (I think that card calls for 26A however.)
------------------------------The voice of REASON
Do NOT feed the TROLLS!
Always a DEMON!
Reply to 4745454b
