memory problem on mobo
Forum Motherboards & Memory : General Motherboard - memory problem on mobo
hey guys for some reason windows only shows 2046mb of ram available when i have 4gigs (4x1024) anyone no y?
spec:
intel core 2 quad q6600 @3.0ghz
msi p6n diamond (X-FI sound)
4gig of OCZ
Nvidia 9800gx2 @ 720/1125
Lite-On Blue-ray
500gb x1
80gb x1
Antec 500 Earthwatt
Window vista ultimate 32bit
Ultimate 32-bit
22" lcd acer monitor
Logitech X-540 5.1 Speaker System
------------------------------ intel core 2 quad q6600 @3.2ghz msi p6n diamond (X-FI Extreme sound) 6gig of OCZ+CoRSAIR oc 900mhz Nvidia gtx 260 sli @ 730/1465/1250
Lite-On Blue-ray Western Digital 7200rpm 500gb Antec 500 Earthwatt Window vista 64-bit
Sponsored Links
It's almost certainly the 32-bit Windows 4GB memory address limit combined with the hardware in your system, especially the 9800gx2, which may use up over 1GB of those addresses on its own.
------------------------------ e2160@3GHz: OCing my way to Ubuntuland!
Reply to Mondoman
really dang it wat a waste of money on 4 gigs.
thanks tho.
Reply to invisik
You should see most or all of your memory under 64-bit Vista.
Reply to Mondoman
Try this:
Start=> Run=> "msconfig"
Go to "BOOT.INI" => "Advanced Options"
Un-check all boxes, hit "OK" and re-boot.
Message edited by Shadow703793 on 06-05-2008 at 07:57:07 PM
------------------------------ http://farm3.static.flickr.com/2617/3815217176_0a5be7955d_o.gif
http://farm4.static.flickr.com/3553/3818083596_1a772f7162_o.gif
Reply to Shadow703793
Vista thinks it needs half of your ram so it caches, takes what it thinks it needs, and leaves you the rest for the rest of your apps.
This is the advanced intelligence built into Vista.
Reply to knotknut
Tom's Hardware > Forum > Motherboards & Memory > General Motherboard > memory problem on mobo
There are 852 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
