Hi guys im having a real headache here im building this new computer and it will start but only for 2 second then shut down and restart on its own and shut downagain in an infinite loop. All the fans are running except for the cpu on that trys to run but only like 0.5 second before the computer shut down. I can also here the Hdd run and my video card fan is running. Also all the leds on my mobo lights up.
Also if I remove the atx_12v_2x the board just turn on and doest go off
here are my computer spec
e8500
GA-EP35-DS3P rev 2.1 bios unknown
Corsair 750w PSU
2xOCZ 2GB Kit DDR2 PC2-8500 Reaper HPC Edition
Sata II seagate 320gb Hdd
9800gtx 512mb
I tryed to run the mobo out of the case samething happens
I tryed all the ram stick individualy samething happens
I tryed resseting cmos by its swicth and removing battery for 10 minutes samething
I heard it might be there rams the motherboard default is 1.8v and the rams are 2.1v so if I remember correctly someone said I had to get in bios to change it but I cant get there and I dont have a spare ddr2 stick
All help is greatly appreciated
edit
Before someone ask I double and triple checked evry connections to the mobo
e8500
Corsair 750w PSU
9800gtx 512mb
edit
