So I sat down and tried to follow the CPU Temp Guide calibration deal that CompuTronix wrote up. I'm not sure if I'm even doing things right. LOL Maybe you folks can help me determine what I'm supposed to be doing.
Ambient = 23c
Chipset = 680i LT
CPU = Q6600
CPU Cooler= Xigmatek HDT-S1283
Frequency = 2.4 Ghz
Load = Prime95 - Small FFT's - 10 minutes
Motherboard = XFX 680i LT SLI
Stepping = G0
Vcore Load = 1.264/1.272
Vcore Idle = 1.168
Now, based on the (x + y) / 2 = z formula, my Tcase Idle should be 32c.
(16+2)/2=9
Ambient + Z = 32c
Now, at IDLE (CPU = 0%, 1600Mhz, 1.168V) I show:
"CPU = 33c"
Core 0 = 34 (ever since installing current heatsink, Core 0 has been higher than the others)
Core 1 = 31
Core 2 = 31
Core 3 = 33
Load Temps (CPU = 100% 2400Mhz, 1.264/1.272V):
CPU = 51
Core 0 = 52
Core 1 = 50
Core 2 = 48
Core 3 = 48
Obviously I don't have the proper spread in temps between my Tcase (CPU) and Tjunction (Core 0,1,2,3). I want to make sure I'm making the proper changes in SpeedFan to get myself set up properly. Now, normally I'd be running a 24/7 OverClock @ 3.2Ghz. But the calibration guide says to run everything on Auto settings. It would appear, that my Tcase is always 1 to 3 degrees HIGHER than my Tjunction. The guide suggests my Tjunction (at load) should be ~3c higher than my Tcase (CPU).
The guide also said, "Tjunction Load = Tcase Load + 5c."
Anyhow, I'm confused as to what I should be doing at this point. Could one of you more advanced forum members help me get things adjusted properly?
My Idle CPU reading was 33c. The formula suggests Tcase idle = 32c. So does that mean I need to offset my Tcase reading in SpeedFan by -1?
If so, that would alter my Load Tcase (CPU) reading from 51c to 50c yes? That still puts it in line with my Tjunction readings. Not sure what I should be doing.
Ambient = 23c
Chipset = 680i LT
CPU = Q6600
Frequency = 2.4 Ghz
Stepping = G0
Vcore Idle = 1.168
(16+2)/2=9
Ambient + Z = 32c
"CPU = 33c"
Core 1 = 31
Core 2 = 31
Core 3 = 33
CPU = 51
Core 0 = 52
Core 1 = 50
Core 2 = 48
Core 3 = 48
