That is looking better.
I have never heard of ODIN before so I can not comment on their quality but the +12V amperage is looking a lot better.
It will defiantly treat you better than the other 350W PSU.
As for it handling 10 years of upgrades...
Probably not.
As PSUs age they loose some of their efficiency and power capacity.
Add to that 10 years of computer evolution and you will probably be missing necessary connectors also.
Besides, if you were upgrading a computer that you made in 1998 would you really want to keep the PSU now?
It should work fine for a few years worth of upgrade cycles but not for ever
