Tom's Hardware Forums » CPU & Components » Other Components » Are OEM parts reusable?
Add a reply
 Word :   Username :
Bottom
Author
 Thread : Are OEM parts reusable?
Profile: stranger
More Information
I am currently using an OEM hard drive that a purchased from newegg a while back. Can I take it out of my current computer and put it in a new one or does it have to be retail?
Related Pr oduct
Ironhide: Why are we fighting to save the humans?
Profile: nimble knuckle
More Information
There should be no issues with the hard drive itself, but the software will have to be reinstalled.
Message edited by Andrius on 05-14-2008 at 02:16:31 AM
Profile: stranger
More Information
One more question: Does the amount of cache in a hard drive matter? Will a higher cache improve my gaming performance or is it more for memory heavy programs like AutoCAD? If I have a low cache will a large amount of memory make up for it? Thanks.
Profile: Forum Veteran
More Information
Larger cache memory can help improve the Hard Drive's performance.
The only affect on gaming would be slightly faster load and save times.
The cache is basically there on the hard drive to "anticipate" what's the next chunk of info programs need. If it is not in the cache, then the program will search for that data on the hard drive.
Q9450 |Corsair XMS 4GB DDR 800 | ABit IP35 Pro | X1900XT 512MB | Audigy 2 | Seasonic S12 550 | Cooler Master Centurion 532 | NEC LCD2690WUXi
There is no such thing as a stupid question.
But there are stupid people.
Profile: addict
More Information
cache size does deal with performance, but mostly in transfering large files. the hd is also used less since it stores info in cache. wlll it have better gaming performance? newer hard drives which have larger cache sizes like my seagate 7200.11 500gb and 750 gb, do have overall better performance. but it's not simply because of larger size, as i understand it.
http://en.wikipedia.org/wiki/Disk_buffer
here's an article what cache is and what it does
werd.
Profile: addict
More Information
As far as I know, cache is a buffer... for lack of a better term, it's' hard drive RAM. If you are moving a 8GB file in between 2 partitions, a hard drive with a 32MB cache will perform much better then a disk with a 2MB cache.
It will increase load times and stuff a bit, but as far as actual gaming, I'm sure that there will be absolutely minimal difference (I would be surprised if there was any).
"Steve Jobs is not making enough money"
E8400 @ 3.6GHz (9x400FSB 1.32v)|4GB|HD4870
Add a reply
Google Ads
