Tom's Hardware Forums » Homebuilt Systems » New System Build » Are these the right parts???
Word :   Username :
Bottom
Author
 Thread : Are these the right parts???
Profile: newbie
More Information
Ok So I can finally upgrade my computer. Well it really like buying a new computer.
The only parts I'm re-using is the CPU, PS, and DVD burner.
OK first of all is my budget it 500 period. I can't go over that because my wife would kill me. :P
These are going to be the parts that I re-use. I like the CPU so don't offer me a Core2Duo. I know the new ones are the best but that will be for a later upgrade.
Ok here it goes.
Intel 945 CPU 3.4 Ghz Dual Core processor
430 Watt Toughpower PSU (I don't know if this will run the new video card i want to get)
Sony DVD burner.
OK here is the list if the new parts I want to get. Now all the prices I found were from newegg. If you guys can find something cheaper and be of better quality then by all means go ahead and let me know.
COOLER MASTER RC-690-KKN1-GP Black SECC/ ABS ATX Mid Tower Computer Case - Retail - http://www.newegg.com/Product/Prod [...] 6811119137 - 84.99
SAMSUNG SpinPoint T Series HD321KJ 320GB 7200 RPM SATA 3.0Gb/s Hard Drive - OEM - http://www.newegg.com/Product/Prod [...] 6822152054 - 69.99
ECS N9600GT-512MX-P GeForce 9600GT 512MB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready SLI Supported Video Card - Retail - http://www.newegg.com/Product/Prod [...] 6814134040 - 149.99
2X WINTEC AMPX 2GB 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Desktop Memory Model 3AXT6400C5-2048 - Retail - http://www.newegg.com/Product/Prod [...] 6820161182 - 73.98 all together
EVGA 122-CK-NF66-T1 LGA 775 NVIDIA nForce 650i Ultra ATX Intel Motherboard - Retail - http://www.newegg.com/Product/Prod [...] 6813188017 - 69.99
I thought of all the basic components for this system. The only thing I'm iffy on is the PSU that I'm re-using. I know that 430 would probably be alright for this system but I'm know sure about the 12-volt rail. I would like you guy's help on what you think. This is going to be mainly used for gaming so I thought I did pretty good for the price and what components I chose. The only real reason I chose that case was because of the size of the heatsink on the Mobo. I looked for the biggest, fattest, case that I could find that was cheap and that was what I found. I even looked for the size specs on that video card and I couldn't find any. Idk. I'm going to be ordering those parts next week so any advice I could get would be great.
Also to let you guys know is I've already built 3 other systems so I'm pretty comfortable with the whole putting together my stuff. I just don't want to be treated like a noob. Thanks. :D
Related Product
Gosh, i love ATI
Profile: addict
More Information
well, note that you could be getting more from your card with a core 2 duo...
that said, i suggest a more notable ram brand, ie gskill, patriot, or corsair...
Profile: enthusiast
More Information
Your PSU might not be enough to power the 9600GT. According to this review, your PSU only has 20 amps on the 12v, whereas the 9600GT recommends at least 26 amps. It also has pretty crummy efficiency...
You shouldn't really have to worry about the size of the heatsink when choosing a case unless you're getting an aftermarket cooler. You could get a cheaper case and use the saved money to get this Corsair 450VX for $59.99 after google checkout with free shipping. But if you like the CM690 and are sticking with it, buy.com has the same case with free shipping: http://www.buy.com/prod/cooler-mas [...] 77908.html
I would have to agree about going for different ram, especially when you can get others around the same price if not cheaper. This set of A-data is $69.99 with free shipping. You can also get some G.skill for $75 with free shipping.
The mobo is a little iffy, but I guess it's hard to beat at that price point. Not sure if it might cause some troubles when you decide to upgrade your CPU in the future though...
Don't forget some thermal paste for reseating the CPU/HSF if you don't already have some.
Google Ads
News
No defects in PS3 stamping parts, says maker
Published on November 21, 2006
Taiwan-based G-Shank Enterprise stated that stamping parts it manufactured for Sony's PlayStation 3 (PS3) game consoles have no defects and should not cause malfunction of the console's card reader, according to a November 20 filing the company made with the Taiwan Stock Exchange (TSE). Read more
Supply of high-density NOR flash said to be tight
Published on December 05, 2005
In addition to supply trailing demand for low-density parts, the NOR flash memory market is experiencing tight supply of high-density parts (above 8 Mbit) from the two leading makers, Intel and Spansion, and the situation is not expected to ease until the first quarter of 2006, according to industry players. Read more
DDR2/DDR price gap narrows to 5 percent
Published on June 30, 2005
The DDR2 512Mbit price premium over DDR 512Mbit has shrunk to 5%, down from 30% in the beginning of 2005, and DRAM supply is expected to run short of demand as memory makers continue to shift production to NAND flash. Read more
Fly eyes for spying cameras
Published on September 11, 2006
Even with our sophisticated cameras, we can sometimes get poor pictures. This usually happens because cameras use an average light setting to control brightness. Read more
Latest Reviews & Articles
Stalker: Clear Sky--Is Your System Ready?
Published on September 30, 2008
Thinking about picking up the latest update to Stalker, but not sure if your graphics subsystem can handle it? Hang on as we take you through a performance tour and demonstrate how the game has been prettied up. Read more
Part 4: Avivo HD vs. PureVideo HD
Published on September 29, 2008
The 780G chipset/Radeon HD 3200 and the MCP78S chipset/GeForce 8200 provide the first integrated graphics solutions that can accelerate Blu-ray playback. We dig deep into how well they work with high-quality Blu-ray 1080p video playback. Read more
Four GeForce 9600 GT Cards Compared
Published on September 26, 2008
Manufacturers really love the first Geforce 9. The graphic chip is fast, the cards are inexpensive, and some retailers offer more than ten variations. Read more
Maxtor's Shared Storage Does NAS At Home
Published on September 25, 2008
What do you do with all the data you collect at home? Network attached storage is the solution. We test Maxtor's Shared Storage II and find that it is also suitable for use in small businesses. Read more
