Tom's Hardware > Forum > Motherboards & Memory > Chipsets & Bios > Bios losing clock speed on power-off
Forum Motherboards & Memory : Chipsets & Bios - Bios losing clock speed on power-off
I have an ASROCK K7S8XE mobo running AMIBIOS 3.31a, I think. Processor is an AMD 2.6G. Machine has been running fine for ages but yesterday it booted up with totally the wrong clock speed.
Motherboard jumpers are set to 166MHZ which it has been running at for years but now it is booting up with 100MHZ, making the machine fall over.
If you clear the bios, it boots up with 166 but as soon as you reboot, it back to 100.......
Tried changing the mobo battery, no help.
I am lost. Any help appreciated.
Sponsored Links
are your jumpers dusty??
sounds like there is something wrong with your jumpers. try a different jumper in the same spot.
Message edited by ilovebarny on 06-07-2008 at 07:34:16 PM
Reply to ilovebarny
do that, and go ahead and flash your bios again, either with a new or same version.
Reply to frozenlead
There are 485 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 vianescute won the Freshman badge
  • 01:00 meywd won the Freshman badge
  • 01:00 nayega won the Freshman badge
  • 01:00 gpfear won the Freshman badge
  • 01:00 Conrad925 won the Freshman badge
  • 01:00 skythra won the Freshman badge
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
