Tom's Hardware Forums » Graphic & Displays » Graphics Cards » Help please - graphics card upgrade only works for a while
Word :   Username :
Bottom
Author
 Thread : Help please - graphics card upgrade only works for a while
Profile: stranger
More Information
Hi there
I bought a Packard Bell box at Christmas just to have a Windows box around the house (I moved to Mac recently). It's very low end so I bunged in an extra 2GB of RAM which made a difference. Next thing seemed to be to lose the slow on-board graphics, so I swapped this for a passively cooled Nvidia 7300GT - didn't want much noise. After a bit of faffing around I finally managed to persuade the machine to ignore the onboard graphics and use the new card instead - so far so good.
Not long afterwards, the splash screen on bootup started to look a bit funny - not illegible but definitely some pixels in the wrong place. This would get worse if the machine had been used recently, and indeed eventually the displays just blanks (it's just done it again after 10 minutes or so).
So...not knowing too much about this, I'm guessing it's a heat issue but not sure what to do about it. I could just get a card with a fan, I could abandon the idea altogether or...what? Could there be something actually wrong with the graphics card?
Apologies if this is real beginners stuff but I'm struggling a bit on this one.
The card in question, incidentally, is an Asus EN7300GT Silent.
Very many thanks in advance for any help you might be able to offer.
Regards
Ally
Related Product
Profile: old hand
More Information
From my understanding of your problem, the bootup screen is all discolored and the display occasionally blanks out?
1. I used to have the problem of a discolored and messed up BIOS startup screen when I upgraded from integrated to an ATI HD 3850. I resolved it by updating the BIOS.
2. If you think the card might be overheating then take the side panel off the computer and blow a fan on the graphics card. See if anything is different.
3. Are you updated to the latest drivers?
4. What operating system are you using? Is it updated?
5. Is http://www.newegg.com/Product/Prod [...] 6814121021 this your card?
6. Do you know how to check the temperature of your card?
7. If all else fails can you exchange it for another one?
Message edited by physx7 on 04-26-2008 at 04:54:14 PM
The evening news is where they begin with 'Good evening', and then proceed to tell you why it isn't.
http://i299.photobucket.com/albums/mm282/alphahuman98/masterchiefdancing_4-1.gif
Sailing in my Dreams
Profile: Forum Veteran
More Information
It also possible that the PSU doesn't have enough power for the card. That 7300GT doesn't take much, but some of those cheap computers were paired with PSUs that were also cheap and barely adequate for the bare computer, much less any add on cards. Check the wattage of the PSU before you do too much more. If its small, 250wt or less, you may have a problem with it. Next, if you can, try checking the card in someone else's computer to verify that the card itself is good. If it is good, check the BIOS and upgrade it if possible, as physx7 suggested. Some cheap machines allow that, others have a locked BIOS. You might also double check that the computer runs with its stock graphics, without the 7300GT.
One thing for sure is that if this Packard Bell is in the cheap, throwaway class of computers, I wouldn't invest very much money in it. There's a lot of computers being sold at or under $500 these days which just aren't worth the money to improve. They are built for simple things; going on the internet, word processing, and so forth, but they aren't able to run anything beyond simple games. Its the old idea of you get what you pay for and you don't get what you didn't pay for.
Evil lurks in the databanks as it lurked in the streets of yesteryear. But it was never the streets that were evil.
Over 50. Seen it, done it, can't remember it.
Profile: old hand
More Information
Sailer wrote :
It also possible that the PSU doesn't have enough power for the card. That 7300GT doesn't take much, but some of those cheap computers were paired with PSUs that were also cheap and barely adequate for the bare computer, much less any add on cards. Check the wattage of the PSU before you do too much more. If its small, 250wt or less, you may have a problem with it. Next, if you can, try checking the card in someone else's computer to verify that the card itself is good. You might also double check that the computer runs with its stock graphics, without the 7300GT.
+1
Thanks Sailer, I forgot about the PSU..:)
Message edited by physx7 on 04-26-2008 at 05:23:32 PM
Google Ads
News
Graphics card makers expect Vista to improve profits
Published on September 23, 2005
Windows Vista, Microsoft's next generation OS, is expected to help graphics card makers see increased profits from rising high-end card demand, according to graphics card makers in Taiwan. Read more
Gigabyte intros entry-level GeForce 6200 graphics card
Published on May 06, 2005
Gigabyte announced a new addition to its product lineup. Read more
Computex: MSI shows X800XT board with AGP and PCIe interfaces
Published on May 31, 2005
MSI displayed at Computex an ATI X800XT-based graphics card that integrates an AGP as well as a PCI Express interface. Read more
Albatron releases AGP-based GeForce 6800GS graphics card
Published on December 21, 2005
Albatron released a new graphics card for users who are looking for a graphics upgrade for their AGP system. Read more
Latest Reviews & Articles
Atom, Athlon, or Nano? Energy-Savers Compared
Published on October 03, 2008
We compared Intel’s Atom 230 and VIA’s Nano L2100 processors hoping to find the best product for low-power applications. VIA is in the vanguard of performance. Is this enough to beat Atom? Read more
Interview: Bigfoot's Killer NIC, Exposed
Published on October 02, 2008
Since its release, the Killer NIC has garnered a reputation for being an extravagant and largely unnecessary add-on for the do-it-yourselfer. Seeking additional insight, we approached the card's designer. Read more
Seagate's 1.5TB Barracuda: Bigger And Better?
Seagate is the first hard drive vendor to offer a 1.5 TB drive in the 3.5” form factor. Meanwhile, WD sent us its RAID Edition 3 (RE3) drive. We tell you which is the best HDD choice today. Read more
Updated CPU Charts 2008: AMD Versus Intel
Published on October 01, 2008
The processor is the heart of your PC, and our updated charts for Q3 2008 show 54 of them competing in terms of performance. Using our updated suite of benchmarks, compare your favorite AMD and Intel CPUs after reading this introduction. Read more
