Tom's Hardware Forums » Graphic & Displays » Graphics Cards » geforce 8800 gts no display on monitor
Word :   Username :
Bottom
Author
 Thread : geforce 8800 gts no display on monitor
Profile: stranger
More Information
I just made my first build. heres the specs
500 watt power supply
amd athlon 5000 cpu
2x 1 GB ddr2 ram
asus m2a-vm motherboard
geforce 8800 gts
320 GB seagate sata harddrive
xp pro
the problem is that when the 8800 gts is in the pci-e slot i get no display on my monitor. i downloaded the correct driver from nvidia but when i try to install, says i can't because there isnt the right hardware (well no **** graphics card isnt in). i assume i need the graphic card in to install drivers, but i cant get into windows to install drivers because i get no display when the card is in. my monitor is connected to the vga on the motherboard because it doesn't have dvi so cant connect directly to graphics card, is this the problem? is there vga to dvi adapter i can get so that i can connect the monitor directly to the card? or do i have to get a new monitor?
Related Product
Profile: journeyman
More Information
Yes you can get a dvi to vga adaptor for around $10 any computer/electronics store
Profile: enthusiast
More Information
Let me get this straight, you have only vga on your monitor but only DVI on your 8800gts? If this is the case, you need to use a dvi to vga adapter. Connecting the monitor to the vga port on your motherboard will not produce graphics from the 8800. Generally with a motherboard that has onboard video, you can chose to enable or disable the onboard side of it in the bios. Your video card could/should have come with a vga to dvi adapter, in which case just use that on the end of the cable to hook up to your monitor. That should correct the problem. If not, you will need to buy an adapter and then I would suggest disabling the onboard video in the bios. Good luck.
Steve
Google Ads
News
Velocity Micro announces first pre-configured Geforce 8800 PC
Published on November 08, 2006
Enthusiast PC builder Velocity Micro is first out of the gate to announce a computer that is available with Nvidia's new Geforce 8800 graphics cards. Read more
Gigabyte Launches GeForce 8800 GT Card
Published on December 05, 2007
Gigabyte United has announced the launch of the GV-NX88T512HP, based on Nvidia's GeForce 8800 GT GPU. Read more
Nvidia Announces 3-way SLI
Published on December 13, 2007
Nvidia has extended its SLI multi-GPU platform to support up to three GeForce graphics cards in one computer. Read more
Nvidia Tesla Powers An Amazing Ultrasound Scanner
Published on June 13, 2008
Santa Clara (CA) - A few weeks ago, we learned about a technology that was fascinating simply because of the fact how current technology advances have an impact not just on how we use computers, but how they improve our life. Read more
Latest Reviews & Articles
Stalker: Clear Sky--Is Your System Ready?
Published on September 30, 2008
Thinking about picking up the latest update to Stalker, but not sure if your graphics subsystem can handle it? Hang on as we take you through a performance tour and demonstrate how the game has been prettied up. Read more
Part 4: Avivo HD vs. PureVideo HD
Published on September 29, 2008
The 780G chipset/Radeon HD 3200 and the MCP78S chipset/GeForce 8200 provide the first integrated graphics solutions that can accelerate Blu-ray playback. We dig deep into how well they work with high-quality Blu-ray 1080p video playback. Read more
Four GeForce 9600 GT Cards Compared
Published on September 26, 2008
Manufacturers really love the first Geforce 9. The graphic chip is fast, the cards are inexpensive, and some retailers offer more than ten variations. Read more
Maxtor's Shared Storage Does NAS At Home
Published on September 25, 2008
What do you do with all the data you collect at home? Network attached storage is the solution. We test Maxtor's Shared Storage II and find that it is also suitable for use in small businesses. Read more
