Finally did a build and I believe I've got some bad parts. I've posted on a couple different sites and just wanted to see what you guy's thought?
Got everything together and wouldn't post with both sticks of RAM, pulled one stick and booted. Just to check thing's out tried the other stick and no boot. Was told by another site to up the vdimm to ram specs, did that and when I tried to reboot I got nothin but case fans running with the one stick, tried the other stick alone and fans start up for about 3 seconds and stop then repeat with no post.
Tried clearing cmos ( pulled battery for 30 mins, used jumper cap and had battery out for 10 hours ) with same result above.
Pulled everything and redid it outside of case and same result. One stick Ram fans just run w/ no post and other stick in alone just the 3 run and restart w/ no post.
Any suggestions? Thx...
Build parts:
E8400 chip
Gig DS3L Motherboard
Corsair 4 GB Corsair XMS2 DHX ram
Corsair 550 power supply
Evga 8800 gts video card
Antec P182 case
Build parts:
E8400 chip
Antec P182 case
