Tom's Hardware > Forum > Graphic & Displays > ATI > problems with my Radeon HD 2900GT
Forum Graphic & Displays : ATI - problems with my Radeon HD 2900GT
Since I installed my Ati radeon hd 2900 gt, I'm experiencing serious distoritions of graphics during gaming. Usually this are stretched textures, and the show up in just about every game I've played. I tried installing the newest drivers and flashing my bios but neither helped.
I'm thinking maybe this has to do with my motherboard a VIA PT880 Pro/ 4CoreDual-SATA2 which is only 4 lanes.
Is anyone familiar with this problem and know how to solve it?
http://farm3.static.flickr.com/2389/2445181243_c0d760b07a.jpg?v=0
http://farm3.static.flickr.com/2310/2301694711_5720d2f4fc.jpg?v=0
Sponsored Links
I read a couple of reviews about your board on newegg and quite a few people complained about smearing graphics and about the board being picky about video cards. Do you have any other video card you can try? From what I read it might very well be the mother board.
------------------------------ Athlon 64 AM2 6000+
Gigabyte M61P-S3
4 GB OCZ Fatal1ty DDR2 800
Asus 4850 512mb
Reply to caamsa
Have you installed the newest drivers?
------------------------------ Needs a job...
Reply to romulus47plus1
- 0 +
@ caamsa
Yes, I've borrowed a Geforce 8800 and it worked without any problems on my motherboard.
@ romulus47p lus1
As mentioned before, i've installed the newest drivers for my videocard and flashed my bios.
Reply to jam_ed
- 0 +
have you tried your vid card on another mobo?
Reply to wip99gt
- 0 +
ya try a new mobo if the problem persists then its ur graphic card call the company u bought it from and they should take care of u and if its the mobo contact the manufacture and complain.
May i ask how old is ur mobo and graphic card?
------------------------------ intel core 2 quad q6600 @3.2ghz msi p6n diamond (X-FI Extreme sound) 6gig of OCZ+CoRSAIR oc 900mhz Nvidia gtx 260 sli @ 730/1465/1250
Lite-On Blue-ray Western Digital 7200rpm 500gb Antec 500 Earthwatt Window vista 64-bit
Reply to invisik
- 0 +
Unfortunately, I don't have access to other mobo's. This card and mobo are about 2 months old.
Reply to jam_ed
- 0 +
I'm sure a local computer store could check your vid card out for you
Reply to wip99gt
- 0 +
I'm already pretty sure the problem is the videocard - mobo combo.
I was just wondering if anyone knows how to fix it...
Reply to jam_ed
Well its pur artifact right there. But if your mobo doesn't like that GPU, which is just weird, then I suggest googling your problem. That seems to work for me when I have a problem.
------------------------------ http://www.steamcalculator.com/76561197970703804/camo_sig.png
Reply to jimmysmitty
There are 1298 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
