2x Amd Opteron Quad Core 2356 Socket F 1207
Tyan S2915 Thunder (n6650W) boards
4x ATP 4GB DDR2-667 ECC RAM (samsung chips)
1x Antec TruePower Quattro 1000W PSU ( EPS12V v2.91 and ATX12V standard)
Have tried 2 of ATI RV630 HD 2600 pciE card
and Leadtek winfast PX8800gts pciE card
and Gigabyte GV-RX30HM256DP-RH pciE card
Chenbro Black 3U 19” Rack-mount Chassis for ATX/EATX
Have plugged in the required EPS12V 24pin + 8pin + 4pin power plugs for mainboard and pciE (8800gts) only
CPU's seem to be installed correctly.
Haven''t got any SATA or pciE nics or cdrom's plugged in
Have read the mainboard book for ddr2 ram installation.
Have tried single and dual ram setup's in
DIMM1 + DIMM2 and DIMM2 + DIMM3 (this is on the mainboard
and in the book it shows as DIMM 0 + 1 + 2 + 3)
Basically i can sometimes get a PRE BIOS post of the video card's
but after that the screen goes blank.
I do get one Short hi-pitched beep with ram in One Bank (DIMM) of ram
One long beep and one short beep with Two Bank's DIMM 2and3 OR DIMM 1and2
No other beep's and that's it
*Have tried different ram, different banks + reseating, 4 different video cards
mentioned, checked all the plugs, different power supply.
Have tried video cards in pciE 8x and pci16x slots
Plus tried PS2 and USB Keyboards, but get error No keyboard
Read the mainboard manual and the online one back to front
Can't think of anything else to check or do
Been building comps/servers for quite some years and checked stuff
inside and outside and got two others 2 check also.
Tyan S2915 Thunder (n6650W) board and two Opteron 8216 (OSA8216AA6cy)which in theory are supported.
(My old Tyan Thunder K8W works fine with these two Opteron 8216)
My problems with the S2915 board are:
1) Where is the pin header to take the pin for Speaker? Without it, I can't hear any beep to guide me through the POST process. I can't seem to find it in the manual.
2) The board does not POST, but everthing else seems ok, checked and re-checked again, including clearing CMOS, etc.
3) Is there any way of finding out what BIOS version the board has (when it desn't even POST)?
There are numerous articles about upgrading the processor/s
from what i have read there is an E version and a non E version of this board. The non E version does not officially appear to support processors with more than 2 cores
has anyone got the non E version working with more than 2 cores ? I have this board and looking to boost performance.
Currently using 1 x 2 core processor running at 2.4GHZ.
If it can be done has anyone experienced any significant performance increases. I've heard than performance improvements are not that great.
If this is the case may just go with 2 x 2 core processors instead.
