Hey guys, I am currently using the 64 bit version of Vista and I came across this sound card - was hoping if people could chime in and let me know if this will work with the 780i board as I have heard rumors that currently it is not supported...
http://www.newegg.com/Product/Product.aspx?Item=N82E16829132006
Also, it says it is PCI Express compatible. Does this mean it will use the 16x PCI-E slot or can it only use that 1x slot? I never plan on running tri-sli, so I would use the middle PCI-E slot. Any advice would be great. Thanks!
