Tom's Hardware > Forum > Graphic & Displays > Nvidia > Hardware detection help!
Forum Graphic & Displays : Nvidia - Hardware detection help!
heres my problem i just bought a Nvidia BFG 8800GT OC 512MB GDDR3, i just got done uninstalling my intergraded graphics, but for some reason windows doesn't detect my 8800GT? plz help i dont know what to do :(
Sponsored Links
Where did you download the driver? It could be an old version that doesn't support new card.
------------------------------ Q6600@3.6ghz, GA-EX38-DS4 motherboard, 8gb 800mhz ddr2 4-3-3-12, 8800GTS(g92)@780mhz, 1TB + 1.5TB hdds, 850watt psu
Reply to dagger
You probably need to disable onboard graphics and enable the new PCIe card in the Bios before it will work.
Reply to roadrunner197069
roadrunner could u pls explain how to disable the onboard gpu?..in the BIOS i set primary as PCIe..but still i only get screen with the onboard..tnx.
Reply to shaykram
There are 1336 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
