Tom's Hardware > Forum > Storage > Hard Disks > HDD problem 2.5
HDD problem 2.5
Forum Storage : Hard Disks - HDD problem 2.5
I took the Fujitsu hard drive out of my laptop to get the pics off of there. I plugged it via USB to my desktop here at work. It shows up as a mass storage device in Device Manager. It doesn't show up in Computer management. Any suggestions?
Here are a couple of screenshots.
http://mrpburke.com/fileupload/uploads/screenshot.jpg
http://mrpburke.com/fileupload/uploads/screenshot2.jpg
I'm using Windows XP. I tried it on my laptop last night(Windows Vista) and it showed it as Disk 1 in Computer management. I tried to initialize it, but then it said the device was not ready.
Sponsored Links
Just to be clear, which menu option (when you right click on the drive in disk management) did you click on?
------------------------------ Desktop | E7300 | P5KPL-AM | 2GB DDR2 667MHz | NVIDIA 9500 GT | ST3320613AS | w2228h
XPS M1330 | T8300 | Dell 0U8042 | 2GB DDR2 800MHz | NVIDIA 8400M GS | WD2500BEVS-75US | 1280 x 800
Reply to r_manic
- 0 +
I tried the initialize disk and like I said it says device not ready . I'll post some screenshots later of how it looks on the laptop
Reply to RUSSH
- 0 +
Here are some screen shots from my laptop in Computer management
http://mrpburke.com/fileupload/uploads/sshot1.jpg
I right click to intitalize disk
http://mrpburke.com/fileupload/uploads/sshot2.jpg
I click ok and it says the device is not ready.
http://mrpburke.com/fileupload/uploads/sshot3.jpg
Message quoted 1 times
Message edited by RUSSH on 06-25-2009 at 03:52:32 AM
Reply to RUSSH
- 0 +
This is so insanely frustrating. I have the exact same problem, except I'm using Vista (home premium 64 bit). I have a regular Serial ATA (SATA) hard drive, (Western Digital green Caviar) 500 GB, and it's brand new. I plugged I into a USB connector, and power supply, and my computer installs it, it shows up in Disk Management (not windows explorer) and basically what I need to do is initialize it, but it just says "device not ready". My first thought was that it may be being used by a program (like when you try to delete a program that's doing something, you get the message that you don't have permission to perform the task...) but I checked my processes and I didn't recognize anything abnormal. I decided to try one of my fancy new programs (active@ undeleting enterprise), and it finds the disk, however, the options are limited. It gives the option to format the disk, but then it says that an unexpected error occurred, and the program terminates. (I don't get it.. why would there be an expected error? Being a software tester, I expect errors... but why would a program expect an error? Windows has some pretty dumb errors...)
Regardless, I'm unable to use my drive, or find anything useful anywhere.
Reply to amlord1
- 0 +
Ok, I JUST fixed the problem apparently.. I believe the issue is a power problem. I took apart my brothers external, and connected my hard drive to the power/sata connection. I then plugged it in, and connected it. Worked like a charm. I guess the other power supply I was using was not supplying enough power.
Might want to invest in a new casing, before sending your hard drive back.
Reply to amlord1
- 0 +
Didi you ever solvev this issue? I have the same problem.
Reply to s2ware
- 0 +
Nope never fixed the problem. I just gave up on it.
Reply to RUSSH
If the device relies on power via USB; there can be problems if the device doesn't get the power it wants. Some USB casings come with two USB connectors; one for DATA transfer and one for POWER. Connecting both to different USB hubs should make this problem go away. If its a power issue. :)
------------------------------ ...man will occasionally stumble over the truth, but usually manages to pick himself up, walk over or around it, and carry on.
Reply to sub mesa
- 0 +
Unfortunatly it does not seem to be a power problem. Using a USB 2.0 to SATA/IDE adapter with separate power supply. Trying to install larger SSD to clone and replace current. Vista 64.
Reply to s2ware
- 0 +
My problem WAS a power issue, even though it didn't appear to be; My computer could see the drive, and it looked as if it should work; but there was not enough power to actually use the drive; I got a new power cable, and it has worked fine since.
Reply to amlord1
- 0 +
Problem solved. Finally got the clue and looked at power. It seems the kit I had to power the SATA drive was missing a powerline in the connector (+12,+5 only). Looking in my old desktop computer the SATA connectors had 5 wires. I plugged it in and it worked. Thank you all for the great advice!!!
Reply to s2ware
There are 901 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
