Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > Not enough PSU power for 2600XT AGP ?
Forum Graphic & Displays : Graphics Cards - Not enough PSU power for 2600XT AGP ?
My friend bought an AGP Saphire 2600XT 512Mb.
When trying to play Diablo or Hellgate, part of the graphics are missing or flashing. Is that a sign that not enough power coming from PSU.
His PSU is a generic nobrand about 4 year old! They recommend 400W or better.
Don't want to make him buy a new PSU to find out it was not the real problem.
Thanks.
Sponsored Links
Who are "they"? "They recommend 400W or better. "
What make and model? "His PSU is a generic nobrand about 4 year old"
Reply to WR2
You're goign to have to find out more information on his PSU.
What brand is it? How many watts is it rated for? What is the amperage across the 12v rails? All this information should be on a sticker on the PSU.
------------------------------ Antec Nine Hundred, Gigabyte P35-DS3R, Intel Q6600 @ 3.2 Ghz, Thermalright Ultra-120 Extreme, eVGA 8800GT 512MB, G-Skill 4GB (2x2GB) DDR2-800 4-4-4-10, Seasonic S12 ATX 650W, Seagate Barracuda 7200.10 320GB SATA, 26" LCD Monitor (1900x1200), Windows XP Pr
Reply to deuce271
Also probably a good idea to mention what else your friend had in his system.
Reply to WR2
There is no sticker on my friend's PSU.
400W recommendation is from the manufacturer as listed on the box.
Are these symptoms typical of weak PSU?
Ex.: You can see only part of the main character. No head or legs. Flashing bottom display.
Reply to jenden
Symptoms of a weak PSU;
-bad 3D performance
-crashing games
-spontaneous reset or imminent shutdown of the PC
-freezes during gameplay
Message edited by WR2 on 04-30-2008 at 10:14:45 PM
Reply to WR2
What drivers are you using ? there is a known issue with that card in AGP flavour.
If you are not already using them try these.
http://support.ati.com/ics/support [...] onID=31542
Mactronix :)
Reply to mactronix
Thanks for the information. I will try the driver first. I will let you know how it turns out.
Reply to jenden
There are 434 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
