ok, as soon as the e8400 is back in stock I am going to be ordering my computer. I have a case and I have XP. Question 1, will XP work with more than 2 gigs of ram, I have heard it won't utilize it, will games utilize it if I got up to 4 gigs?
question 2, here is my hardware, I plan on playing mostly Oblivion, UT3, and then crysis. am I in decent shape with this config:
PSU
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139004
GPU
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130318
RAM
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231144
MOBO
http://www.newegg.com/product/product.aspx?item=N82E16813128059
CPU
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115037
Optical drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16827101131
I also have a seagate barracuda 7200.8 1.5GB/s SATA
I know it owns all of the system requirements for the most part, so anyone have any experience with a similar config.
also, I have never put a PC together, am I going to have any trouble if I follow the instructions with the mobo and other components? I heard "wear your strap" what does that mean?
thanks!
PSU
GPU
RAM
MOBO
CPU
Optical drive
thanks!
