Archived from groups: alt.tv.tech.hdtv (More info?)
I have a 5 year old Mits HD model number WS55807. Recently I have had
some reception problems and had them fixed. Now when I change the input
to show 1080i, I get what looks like a horizontal hold problem. When I
look in setup I am only able to show RGB, I can't get the YPrPb to
show. I have had a local TV repair guy try to attemp but no idea as of
yet. Does anyone have any ideas as to what might be causing this. I
have tried numerous wiring combination to no avail.
I presume you are using an external HD tuner or cable box? if so then when
switching modes, from HD to lower resolution, you may see loss of sync while
the set catches up to the supplied signal's sync,etc. Also the aspect may
vary depending on the supplied material from the external source.
"Insdoc" <jgeisbauer@earthlink.net> wrote in message
news:1123452889.613525.31350@o13g2000cwo.googlegroups.com...
Be more specific and someone might be able to help. What kind of reception
problems and what was done to fix? How does that relate to this problem?
What source are you using? Setup menu in what device, the TV? Does the set
give a display that indicates it is in 1080i mode?
I am using Charters Cable box. The service tech did a "Complete Repair
and Rebuilt Dynamic Circuit". The reason he did this was to repair
green tinting on the left and right side of the screen. The setup menu
was on the TV. In HD Mode I am not able to set to YPrPb only RGB. On
the screen it does show 1080i Standard. The only way I can describe the
reception problem is "horizontal hold" of much older TV's.
news:1123536411.017432.110840@z14g2000cwz.googlegroups.com...
> Thanks in advance
> Jim
What do you mean by the statement "In HD Mode I am not able to set to YPrPb
only RGB?"
It sounds like your cable box is set to something other than 1080i. The
tech who repaired the set may have set the option menu to force the DTV
input to 1080i to adjust the convergence and did not set it back to auto.
Press MENU then the sequence 8,7,2,0. Set the DTV port to auto, hit menu to
exit.
On the TV, when I set the input to 1080i and try and set the DTV to
YPrPb my only option is off or RGB, yet when I set the input to Cable I
can set the DTV to YPrPb. The cable box was not touched, do you mean
the TV is set to something other than 1080i?
I have contacted a Mits Certified repair and they want to charge $70
for the house call. I don't mind the cost, but after awhile this might
become a big whole to poor money into. So far I am in for $500.00,
small price against a new TV. I just can't help but believe its
something very simple.
Leonard, thanks for the input. I was able to perform the above,
although the sequence was 8,2,7,0. It was set to 1080i. It fixed the
Horizontal hold problem. Now I can't get any audio or video when
changing the input to HD and going to the HD channels. Everthing else
is working fine.
"Leonard Caillouet" <no@noway.com> wrote in message
news:LrQJe.451$Kp.85@bignews6.bellsouth.net...
>> Thanks in advance
>> Jim
> YPrPb only RGB?"
> to exit.
> Leonard
Try re-initializing the set. Sometimes the microprocessor register gets
trashed and it doesn't know how to talk to the other serial controlled chips
in the set. The (SONY) chip that switches inputs is one of those that I've
seen have problems.
news:1123549307.568145.305600@g43g2000cwa.googlegroups.com...
> is working fine.
> Thanks in advance,
> Jim
Oops, got the numbers reversed. Sorry.
OK if you got the H correct, your STB is set to output something other than
1080i and you need to know what it is.
What do you mean by "changing the input to HD and going to HD channels?" Do
you mean changing the input to DTV? How do you know that your H problem is
fixed if you have no video? You need to describe your setup carefully and
use the correct terms for each device.
