Tom's Hardware Forums » CPU & Components » Power Supplies, PC Cases & Case Mods » Chieftec Case anyone? need hard drive cage ideas
Add a reply
 Word :   Username :
Bottom
Author
 Thread : Chieftec Case anyone? need hard drive cage ideas
I hear its amazing when the famous purple stuffed
Profile: stranger
More Information
Back ground Description:
I bought a chieftec matrix full tower case about 5 years ago, because I wanted a case that was heavy duty, has lots of room for expansion, looks nice, and that I could keep around as long as possible
Its served me well and holds up like a champ, but 5 years ago and whenever it was designed, graphics cards werent a foot long, this thing is massive as you can see http://www.tigerdirect.com/applica [...] =MTX-BL-UF
it has removable hard drive cages that slide to the rear of the case, and that wasn't a problem until the 8/9 series nvidia cards, so far I just searched (and luckily found) for a shorter than typical graphics card, but I want to figure out a solution for future upgrades,
What I'm looking for:
-suggestions on modding (I have a dremel and I know how to use it)
-links to any sights that might sell modular drive bays that mount sideways in the case
-opinions, should I upgrade to a new case? or stick with it
-tips on other places I can securely store my hard drives in the case ( need to find a new home for at least 3)or different mounting locations
i've seen 5.25" to 3.5" bay adapters
Related Pr oduct
Add a reply
Google Ads
