actually, now i checked , real crysis gpu temp is 80 and 85 celsius.(no OC 50% fan speed) is it realy normal?
By the way , i use rivatuner tu confugure fan speed, but after reboot fan speed set automaticaly to defoult (45% - about 760 rpm). Is there any way to hold set fan speed for all time?
There's probably an option to enable your custom settings when Windows boots, but I'm no expert on RivaTuner.
set it to 100% in riva tuner and u will never bother with it mine never goes above 55C in anything. i am running a antec 900case with a ton of highspeed fans though.
those temps are ok....that vore can reach very high temps. If you want to make em cooler tho set ur fan speed using riva tuner...60% is a good compromise as its still pretty quiet
Try using this from EVGA, itll give you on screen temps, controls fans and clocks, both core and shader, and like I said itll display in game, temps, speeds and all. Great tool, it may help http://www.evga.com/articles/405.asp
Message edited by jaydeejohn on 05-01-2008 at 11:59:40 PM
------------------------------I went drifting, thru the capitols of tin, where men cant walk and cant freely talk, and sons turn their fathers in
Reply to jaydeejohn
You could OC the 9800GX2, just bring the fan speed up. If the gpu temp disturbs you that much, perhaps some reapplying of thermal paste could help, but I think it's perfectly normal and fine.
------------------------------"Nvidia, the Way It's Meant to be PAID Played! - Corrado
*Lesbian Lover Club* - founder Assman
Reply to Evilonigiri
Reply to jaydeejohn
Reply to jaydeejohn
Same with this tool. Unwinder made both of them. Its just easier with this tool
Reply to jaydeejohn
im sort of stealing your thread but my question doesnt warrant another thread... my 9800gx2 is idling at 60c. to me that seems ok, but im just asking to be sure
the GX2 is a dual GPU meaning 2 graphic cores. It will be hotter than other cards. Considering its 2 8800 GTS G92s. It stays cooler than their old Dual GPU cards though.
Like most people said oc the fan and get a higher speed... I don't see it as necessary because 70 in a demanding game like crysis is very good.
My temps Idle 55 at 45% fan and get up to 65-70 in games soo meh its all good.
------------------------------Folding@HOME Team: 163116
Lapped CPU
Reply to L1qu1d
