Not really, with modern games even all movie data is copied. Some games still require the CD/DVD in the drive, but only for copy protection purposes. So the speed of your optical drive only matters for installation, not in any case game performance.
------------------------------...man will occasionally stumble over the truth, but usually manages to pick himself up, walk over or around it, and carry on.
Reply to sub mesa
Only if the game actually uses the DVD during gameplay for something else other than ownership verification.
Depends on the design of the game of course. "Pong" wouldn't need to be moving very much scenery into RAM. Just to get an idea of the rates involved there is table of DVD drive speeds:
Code :
speed Data rate Disc write time* Equivalent CD rate CD reading speed
All high speed drives will spin down after a while. This is done because letting it spin at high speed all the time would dramatically reduce the life of the drive.
If the game (or other program) wants to access the drive again, the drive has to spin up. This will take a few seconds and might be enough to cause trouble with some games.
However there is a utility which will allow you to change the spindown time.
It can be found at:http://www.ncf.carleton.ca/~aa571
Some drives (Plextor) allow you to select the spindown time.
The spinup/down time can be measured with CD Speed 99."
A non-gaming consideration is data backup to a DVD.
Its more than a bit disingenuous to suggest that only "Pong" wouldn't benefit from a faster optical drive.
Can you name a big-time FPS that uses the DVD for game play?
Just so you guys know, I'm not thinking of getting Pong.
I might get Far Cry 2 though.
D'you think Far Cry 2 is used only for ownership verification? Or does the game need the DVD?
------------------------------mATX Intel DG35EC | Intel C2D E7400 @ non-OC 2.8 Ghz | XFX 8800GT | 500GB Seagate | 4GB OCZ DDR2 | 650 W | NZXT Zero 2 Full Tower | Windows Vista Basic x32 | @1680x1050
Reply to notguru
I use Vista for my main gamer....... and if you go to start/games......... when it loads, if you right click on the FarCry2 icon and select play........... it'll run without the dvd.
As far as dvd-rom drive speed............ never really noticed that any game ever got hampered going from one drive to the next from one machine to another.......
None of my game s use the disc for anything other than copyright crap. And for the copyrighted games i have disc images mounted to virtual drives, which would be the fastest way to assess a cd or dvd.
I do I do the whole mounting images business. Do I need special software like Alcohol 120%? Is anything free?
Do you think this looks reliable?: http://www.slysoft.com/en/gamejackal.html
I've used Jackal in a trial - about 75% at the time, so I let it go.
one more question.....or statement rather:
when i tried playin crysis it asked me for the dvd.
so i guess games do require the dvd
how do i use virtual clonedrive (slysoft.com) to create ISO image of crysis?
Reply to notguru
Virtual clone drive does not rip the image, that's what the other two products combine to do. VCD is merely the mounting place for the image, a virtual DVD drive.
So then how do I make the image?
Reply to notguru
