Tom's Hardware > Forum > Motherboards & Memory > General Motherboard > If I buy a computer with 1200Watt PSU, power...
Forum Motherboards & Memory : General Motherboard - If I buy a computer with 1200Watt PSU, power...
1200watt SLi confi... I know that's equivalent with like an air conditioner running. do i have to worry bout my electronic bill?
Sponsored Links
It has to do with your components. Nothing in existance can use all the power that 1200watt psu can pump out. Power consumption would be only a little more than if you use a 800watt psu. Higher wattage psu tend to be a little less efficient on lower load, thus, the small waste.
------------------------------ Q6600@3.6ghz, GA-EX38-DS4 motherboard, 8gb 800mhz ddr2 4-3-3-12, 8800GTS(g92)@780mhz, 1TB + 1.5TB hdds, 850watt psu
Reply to dagger
also, it may be rated at 1200W but if your system only needs 600W that's all it will draw.
Reply to BUFF
well, that is, not taking efficiency into account ;)
------------------------------ -"From whence you came you shall remain, until you are complete again!"
Peter Mitchell
Reply to rammedstein
Kind of useless to get a 1200watt psu, since most components don't draw more than 700W in total.
Reply to Shadowthor
1200 watt is way overkill.
But it won't "use" any more electricity than your components will draw.
Reply to jitpublisher
Are you sure? How about a Quad SLI 9800GX2 + 8 HHDs + Skultrail with top of the line CPU (2*QX9775)? :lol:
------------------------------ http://farm3.static.flickr.com/2617/3815217176_0a5be7955d_o.gif
http://farm4.static.flickr.com/3553/3818083596_1a772f7162_o.gif
Reply to Shadow703793
Nope, I'm sure you can still pull it off on a 1000watt psu. :na:
Reply to dagger
There are 1219 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
