I have been on TH, MySuperPC, newegg for two weeks. I would like to build my own computer for experience, and to have fun with a new computer.I will use the computer for movies, games, and applications. I want to spend $915(1115 total) I have already have a Q6600 with GO stepping. What parts can I buy for best performance/price?
*sigh* Antec Sonata III 500 case w/500W Antec PSU Gigabyte P35-DS3L mobo... if you need features the DS3-R 2GB or 4GB of 800 MHz DDR2 (I've had success with Gskill for cheap builds) Hard drive space for your needs? 640GB is $110 right now at Newegg 8800GT (on sale last I checked) for ~$190 before $30MIR Optical
Off the top of my head that looks to be around $600 additional... try working it from there.
-mcg
Message edited by MrCommunistGen on 04-22-2008 at 11:23:10 PM
Gen's build is a good start, though I would probably step the video card up to a 8800GTS. Your budget is pretty workable, so you don't really need the Sonata III combo unless you really like the look of the case. Look for a case you like and throw in a 550VX in there.
I just suggested that case because it's really quiet and the PSU should run a single 8800GT fine, and will save money for other things. I would definitely suggest an OC with a Q6600 to get more gaming performance out of it.
-mcg
Message edited by MrCommunistGen on 04-23-2008 at 01:02:41 AM
Ok, thanks the help. So far I am at Q600 (202.00)
Thermalright IFX-14 (75.00)
P35-DS3L (89.00)
2x Cosair DDR2 1066 (94.00)
Zotac 8800GT (230.00)
Lite-on DVD-DL (30.00)
Lite-on DVD-Rom (18.00)
His links go to:
COOLER MASTER Centurion 5 CAC-T05-UW Black Aluminum Bezel
Intel Core 2 Quad Q6600
GIGABYTE GA-P35-DS3L
ZOTAC ZT-88TES3P-FCP GeForce 8800GT
COOLER MASTER Real Power Pro 650W Power Supply
CORSAIR XMS2 2GB (2 x 1GB) DDR2 1066
Thermalright IFX-14 CPU Heatsink
LITE-ON Black DVD±RW with LightScribe
Sony NEC Optiarc Black 16X DVD-ROM 48X CD-ROM IDE
That list is outdated. The 1066 will work fine, but isn't really needed with the Q6600. As long as you don't get unlucky parts, with 800 ram you'll be able to get to 3.6GHz with proper cooling.
