Tom's Hardware Forums » Homebuilt Systems » New System Build » Help Build Multi-monitor PC
Add a reply
 Word :   Username :
Bottom
Author
 Thread : Help Build Multi-monitor PC
Profile: stranger
More Information
I want to build a system around a Q9450 -
Originally I wanted to build an SLI configuration -
I have been reading about moherboards and CPUs.  Between a lot of people saying SLI motherboards are unstable and have problems, and people also saying SLI in no longer worth it, I'm not sure what to do anymore.
I want to be able to drive more than 2 screens (dont ask why - I just need to ) :)
Can i get a non-SLI motherboard, one good Nvida card as a primary to do 3d on, and a less expensive second video card that can drive the additional screens for when im doing work on the desktop?
If so, please suggest some configurations.  I think this would work but I'm scared of picking components without recommendation.
I would like to overclock, so if I can make the above work, I am leaning towards a DFI x48 cipset  Motherboard unless somebody convinces me out of it :)
Thanks for reading!
Thanks !
Mike
Related Pr oduct
Profile: enthusiast
More Information
You should be able to use two videocards to run more than two monitors.
Profile: enthusiast
More Information
You should note that nvidia graphics cards cannot support more than one screen while in SLI.
The 3800 ATI cards can maintain crossfire mode when using two or more monitors.
http://en.wikipedia.org/wiki/ATI_C [...] NVIDIA_SLI
| Q6600 @ 3.2 GHz | Maximus Extreme @ 400 MHz | 2GB OCZ Platiunum DDR3 @ 1600 MHz | Sapphire  HD3870 @ stock| Creative Fatal1ty Professional Series | Diamond ATI Theater 650 PCI-E | 500GB Samsung SpinPoint T Series | ABS Tagan BZ 1100W | Thermaltake Armor
Add a reply
Google Ads
