Tom's Hardware Forums » Graphic & Displays » Graphics Cards » Help! Got some thermal paste smeared around
Add a reply
 Word :   Username :
Bottom
Author
 Thread : Help! Got some thermal paste smeared around
Profile: stranger
More Information
Hi, I'm not sure what to do.  I was installing an Antec Iceberq 6 VGA cooler on my XFX 7900 GT and while I was applying the thermal paste I got some of the arctic silver smeared around outside of the core.  i can't really clean it very well because of the small metal pieces sticking up.  Will my card short if I put it in like that?  Is there anything I can do or is it a lost cause?  Thanks for the help.
Message edited by ravrius on 05-07-2008 at 08:28:42 PM
Related Pr oduct
Profile: journeyman
More Information
Take a painting brush.  Soak the tip mildly in iso-propyl alcohol or other non-conductive cleaner. Just clean the thermal paste.
And see if it's thermal compound containing metal particles like silver or copper. If not, it won't damage, rather cool those circuits it got smeared on. What is the name of thermal paste you used ?
Message edited by hsetir on 05-07-2008 at 04:35:24 AM
Profile: stranger
More Information
Its the vantec thermal paste that comes with the iceberq.  It doesn't say...but the stuff is all white
Because Mike Rowe said so!
Profile: nimble knuckle
More Information
I used a qu-tip with alcohol on mine. I had this issue with my old x1900xtx when i installed the cooler a few times.  Don't knock off those metal things they are resisters.  Better to clean it up as well as you can an leave it alone. I don't think that past is electronically conductive.
E6400@3.2ghz w/ Thermalright Ultra-120  Asus P5W DH Deluxe
4x1GB Crucial Ballistix PC6400 4-4-4-12   CoolMax 600W PSU
XFX 8800GTS Alpha Dog (@750/1000)      Dell 22" E228WFP
Seagate 250GB ES.2 & 250GB 7200.10     Creative X-Fi XtremeGamer
Add a reply
Google Ads
