I have just moved my computer and now have issues with it.
When i turn the pc on it starts up and i can see it starting up on the screen however it then goes black.
I have to push a button on the screen to changed it from digital to analog before i can then see the sign in screen.
I then go through to the main vista screen. I can see all the icons in analog mode but if i put the screen back to digital input the task bar is gone and most of the icons are not there and i cannot get any control panel or screen up.
Another problem in analog mode is that my mouse keeps disapearing.
So problems summary:
1. i start up in digital but need to change screen to analog to sign in
2. I then go onto the main vista screen but my mouse keeps disapearing
3. If i switch back to digital at this stage i have no task/start bar and cannot get anything to work.
Some help would be awesome.
Thanks
Lee-ann
Thanks
Lee-ann
