Yes No
Ads
Tom's Hardware > Forum > Graphics & Displays > Graphics Cards > problems with 9800gx2
Forum Graphics & Displays : Graphics Cards problems with 9800gx2
Just bought a new 9800gx2 stuck it into turned the computer on and no display. after about a min i hear the window log in sounds so its booting up just fine i just cant see anything on my monitor its getting no signal. im using a dvi connection. the card lights up green and blue showing its getting full power so i dont no wat the problem is. psu not enough? but y r the lights not red?
This is my system spec
q6600 @3.0
msi p6n diamond
9800gx2
antec 500 earthwatt
4gig of ocz ram
windows vista 32bit
Please help a noob thanks.
------------------------------ intel core 2 quad q6600 @3.2ghz msi p6n diamond (X-FI Extreme sound) 6gig of OCZ+CoRSAIR oc 900mhz Nvidia gtx 260 sli @ 730/1465/1250
Lite-On Blue-ray Western Digital 7200rpm 500gb Antec 500 Earthwatt Window vista 64-bit
Reply to invisik
Sounds to me like your PSU could be struggeling to deliver enough power.
The 6/pin & 8/pin power connectors on the 9800GX2 card, will light up either red or green, according to if the card is getting enough juice -or simply connected properly. Check your status indicators!
9800GX2 uses about 360W on it's own under full load. Then you have to take the rest of your system into account. My guess is that your system is banking on the max. of what your PSU can produce in wattage.
Message edited by Eizo on 05-07-2008 at 09:40:51 PM
Reply to Eizo
- 0 +
the status indicator is on the back its green and the other 1 turns blue looks like its getting the power and lets say the card didnt get enough power y do i hear the windows log in sound seems like it working and the cpu/hard led on my case seem to flicker on and off. so it seems like everything is fine maybe card defect?? idk?
Reply to invisik
- 0 +
I'm well aware of the indicators on the back of your card.
The indicators I'm mentioning are located a different place. They are placed where you actually plug the two power connectors into the card from the power supply.
Open your cabinet case, turn on your system and check your light indicators on top of the graphic card, where you actually plug in your power to your card.
You're quite right, that it's wierd your system is running in the background. Check your cables to your monitor are plugged properly DVI and power, they could have accidentally fallen out while installing the card.
Maybe you've connected the DVI cable to the wrong connector on the graphics card, try the other one instead.
Reply to Eizo
- 0 +
nvm it works i took the card in and out didnt work but for some reason the 4th time did they trick now it works perfectly fine. Thanks for all ur help tho.
Reply to invisik
- 0 +
Np m8!
Good to hear you got to work!
Happy gaming :D
Reply to Eizo
Eizo was on the money.
I recently bought this card, the 9800 GX2 and with only a 650W power supply, was struggling with this exact issue.
After 2 minutes of running the computer, the screen went black, yet everything was still running sweet.
So I had only 120 seconds to go to Google and type 9800Gx2 Problems, found this thread, and got an understanding of the issue.
Thought it might have been the CPU not keeping up the pace with the graphics card.
So I removed the power and data cables from one of the DVD's and now, its all fixed.
Reply to meclazine
I too have precisely the same problem.
No DISPLAY!
I have a corsair 750w psu. Only hardrive and one DVD drive connected. Mobo is asus rampage, cpu E8500 core duo, 4gb DDR2 RAM
Looking inside the PC every harware aspect looks fine, all LEDs glow lik they should, none of them indicating any problem.
Monitor is a LCD 22" Samsung.
THis is a brand new computer, nothing is one it.
This is so frustrating. :(
Reply to raulduke
just found another thread with same problem
http://forums.hardwarezone.com.sg/ [...] t=1919223.
My card is from MSI too
Reply to raulduke
- 0 +
i found out wat the problem was. my 1st dvi port was not working but the 2nd one works fine. im gonna return the card and buy a gtx 260. =]
Reply to invisik
- 0 +
lol the first DVI is meant for dual, and the Second 1 is the primary:) its not broken:)
------------------------------ PSN: L1qu1dat1on
i7 920 @ 4.02 GHZ, OCZ 6 gig DDR3, EVGA/PNY 480 GTX sli, Corsair 1000HX, Windows 7 Pro 64, 128 Gig SSD + 2 TB Seagate
Reply to L1qu1d
There are 1860 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Bad PCI-E Slot or Bad Graphics Card?
By smorizio, 2 hours ago:
check that you have all the power cables plugged into your video card..some have one some...
Best offers
Top experts
