Yes No
Ads
Tom's Hardware > Forum > Storage > Hard Drives > Partition problems
Partition problems
Forum Storage : Hard Drives Partition problems
I was using partition magic on my external hard drive to make another partition on it. I was decreasing the size of an already set partition and then using that space for the new partition. During the process the power went out. When I powered the computer on the original partition was not viewable in My computer like before. I then opened partition magic and it showed the partition but it was an unknown name. I then ran testdisk and it could read the partition and all my folders in it, but I could not figure out a way to make it viewable again. Any suggestions? Thanks.
Reply to jdelp
Hi jdelp, I suggest you use testdisk to recover your files first. Is it possible to make an image of the partition? If so, then just format the hard disk completely, rebuild the partitions, then just restore the partition images.
------------------------------ Desktop | E7300 | P5KPL-AM | 2GB DDR2 667MHz | NVIDIA 9500 GT | ST3320613AS | w2228h
XPS M1330 | T8300 | Dell 0U8042 | 2GB DDR2 800MHz | NVIDIA 8400M GS | WD2500BEVS-75US | 1280 x 800
Reply to r_manic
- 0 +
Sorry I have been out of town and busy with work to be able to try this. I connected the HDD again last night and I could not get test disk to find the messed up partition. I tried for about one hour with no luck. Nothing has been changed since the HDD has just been sitting unplugged for the week-2 weeks since this post.
Reply to jdelp
There are 1854 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Connecting a Laptop Hard disk directly to Desktop (SATA)
By RetiredChief, 47 minutes ago:
fantastik250 - Sata interface is only for data. Does not adjust any voltages. power is...
Best offers
Top experts
