Hello,
I upgraded the RAM in my PC up to 6 gb and was hoping to install XP 64 so that my system can actually take advantage of it. I am installing onto a new(ish) HDD as well that was empty before. I did the full format just to be on the safe side, and all was going well until setup hit a roadblock and I started getting the following message:
"Setup was unable to access files needed to continue." After trying again several times, I eventually get this:
"An error has been encountered that prevents Setup from continuing. Setup failed to install the product catalogs. This is a fatal error. The setup log files should contain more information. Press OK to view the Setup log file."
I did some research online and most people said that reformating the drive and starting over usually did the trick, but...whenever I restart, setup takes over and goes right back to where it was without giving me the option to start over. So I'm in a sort of XP 64 install limbo and I can't seem to get out!
Any ideas as to what I can do?
