Tom's Hardware Forums » Homebuilt Systems » New System Build » Updated New system build
Add a reply
 Word :   Username :
Bottom
Author
 Thread : Updated New system build
The newb enquirer
Profile: enthusiast
More Information
As the title implies this is my revised system build, it will be used mostly for medium-high gaming (hence the 8400 and 3870) and Overclocking
 Antec Nine Hundred
http://www.newegg.com/product/prod [...] 6811129021
 ASUS RAMPAGE FORMULA
http://www.newegg.com/product/prod [...] 6813131284
Gecube Radeon HD 3870 512MB
http://www.newegg.com/product/prod [...] 6814241071
 Thermaltake  750W Power Supply
http://www.newegg.com/product/prod [...] 6817153038
 Intel Core 2 Duo E8400 Wolfdale
http://www.newegg.com/product/prod [...] 6819115037
 mushkin 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800
http://www.newegg.com/product/prod [...] 6820146731
I've already found a floppy drive and a DVD drive so no need for help there but I need help finding a Harddrive, i'M thinking of doing Raid 0 for speed, I don't need a lot of room so anything going over 500Gigs would be a waste.
I'll also be using windows vista ultimate
I will not be building this computer for a few months so saving and special offers do not matter
It is a very newb question, which is why I ask it.
Related Pr oduct
kad
Profile: addict
More Information
So Great
With this amazing rig I advise you to go with better ram
For  115$
http://www.newegg.com/Product/Prod [...] 6820146726
and better for 120$
http://www.newegg.com/Product/Prod [...] 6820146755
If you'll not go crossfire add 40$ more and get 8800GTS(512MB)
http://www.newegg.com/Product/Prod [...] 6814127325
So in my opinion add one more 100$ and get almost a high end PC
Of course you still need HS+Fan For overclocking
Thermalright Ultra-120 Extreme
Scythe S-Flex SFF21F
kad
Profile: addict
More Information
By the way Get your Graphic card  8800GTS9 (512MB) and Muskin Ram  ASAP cause they are running out of stock
The newb enquirer
Profile: enthusiast
More Information
truth be told the video card is the one thing that's gonna be subject to the most change, as the computer isn't gonna be built for another couple of month i'll probly put in a 4870 or 4870X2 or 3870 CF  depending on the price and performances
also in the difference between the (5-4-4-12) memory and the (4-4-4-12) memory enough for the 25$ difference?
Ironhide: Why are we fighting to save the humans?
Profile: nimble knuckle
More Information
Not really unless you care about benchmarks. 1-3% best case real world. Newegg also has Corsair DHX 4-4-4-12 (for $104 after MIR http://www.newegg.com/Product/Prod [...] 6820145194 ) It might be worth $14 to you but then again it might not.
This same rule applies to the motherboard IMO. You picked a high end motherboard.
What features does the RAMPAGE FORMULA have over the MAXIMUS FORMULA to be worth $25 more ?
What features do both have to be $50 or $75 more over P5E? Are they worth it?
Message edited by Andrius on 04-27-2008 at 02:52:54 AM
The newb enquirer
Profile: enthusiast
More Information
rampage has the EPU which i've been unable to find anywhere else, but you do have a good point there, I'll probly go with 4-4-4-12 to squeaze all the juice possible
The newb enquirer
Profile: enthusiast
More Information
Speaking of which are there any other motherboards that can lower their power comsumption when the computer's not being used and also what would be a good harddrive? I'm thinking 2 or 3 way raid 0 with a combined max of 500 gigs...
Anyone got any ideas?
More Information
RAID 0 increases the chance of failure with each added drive. 2 x 320GB single platter would be the way to go.
I would recommend 1 WD6400AAKS for $110 from newegg(new drive, 2 platters, beats a $90 500GB drive in cost/gigabyte and performance).
If you are thinking of 3 drive RAID think about RAID 5 (data redundancy + performance increases).
WR2
Profile: Honorary Poster
More Information
What kind of applications do you use that make RAID 0's potential trouble worthwhile?
Ditch the Floppy Drive and get a Flash Card reader and a USB Flash Drive (thumb drive) instead.
More Information
P5E (X38 DDR2) has EPU as well (just so you know):
http://www.asus.com/products.aspx? [...] odelmenu=1
Quote :
ASUS Power Saving Solution
 ASUS EPU
Enables the Most Energy Efficient Motherboard in the World...
The newb enquirer
Profile: enthusiast
More Information
I reason why I want raid is because I really want my computer to boot up fast and since the harddrive whill probably be the slowest component, I might as well speed it up, also the reason why I want under 500Gigs (other than the waste it wouls as i've still never broken the 100 gigs mark) is that I'll backup on a 500Gig portable.
I actually forgot to look at how much space i'm using right now (90 gigs with pretty much all the crap in the world installed), that hard drive looks tempting but chances are quite good that I won't even reach 250 Gigs  (I don't do video editing or anything really space consumming)
The floppy drive is also a card reader (I need to use floppies every now and then) and already got a 4gig flash drive (which by the time I get the computer will probly be a 8 or 16 gig one)
[url]
http://www.newegg.com/product/prod [...] 6820223072[/url]
kad
Profile: addict
More Information
Asus Rampage Formula has overclocking potentials more than Maximus and P5E
Also If you can get CAS 4 memory for additional 25$ why to get CAS 5
Note that high end memories became unavailable and I believe manufactureres stopped making DDR2 and started DDR3, you can check Newegg and notice the invasion of DDR3
Hurry up and get your DDR2
Add a reply
Google Ads
