Im using a Q6600 Processor & Bundled Intel Fan. My M\B is Intel DG33FBC my problem is The Fan does not adjusting Speeds Itself It Works Every time On 1140 RPM. Speed Fan shows sometimes My Core temperature 71C. And Doesnt Sensor My Fan. Im confused on this Plz Can you guys help me?
CPU Fan Control Advanced > Boot
Configuration
• Enabled
• Disabled
Allows the CPU fan to be controlled in order to optimize
acoustics. If disabled, the CPU fan will run at 100%.
Where are you reading 71ºC?
and make sure you got the fan connected to the right place on the motherboard.
