I just had a system built today, and I'm concerned that my CPU and GPU temperatures are too high. I have an E8400 processor with the stock fan and an MSI 8800GTS OC video card.
The CPU fan actually stopped running a half hour ago or so, but I think it was because the power cord from the fan was too close to the actual fan blades, so it shut itself down, which led to my computer shutting itself down. I think that is under control now but it's disturbing that it would just cut out if the cord moves a few centimeters. Now it is running at 46C according to my case temperature gauge, but I think it's a good deal higher if I actually look at it in the BIOS. What is a reasonable temperature when under a reasonable load, and how can I monitor this more accurately without rebooting my computer to look in my BIOS?
My video card was up to 68C as I alt-tabbed out of WoW and checked the NVIDIA monitor. I tried turning from automatic fan control to direct fan control, and moved it from 34% to 44%, but to be honest I'm not sure what that even means. When I select direct fan control, it un-grays an option that just says "GPU (3D) and then has a slide bar, followed by the percentage, a slash, and then the temp. I'm confused, and sort of worried about the early going here.
What do you recommend?
Thanks!
Thanks!
