i got a new 8800GT and bought the coolermaster extreme power duo 600w with it .
now the motherboard has ATX 12v 8 pin connection socket while the PSU has only one 4 pin 12v cpu power connector . my processor is e8200 with a TDP of 65W. so i can use the 4 pin connector in the 8 pin socket safely .
the confusion is that which of the 8 pins i use on the motherboard ?
there are three options -
1. use the four pins nearest to the CPU .
2. connect the 4 pin connector right in the middle of the 8 pin connector on the mobo so that two pins are empty on either side.
3. use the four pins farthest from the CPU.
the motherboard is XFX 680i LT. can anyone please tell me which of the above three options can i use . i will be really thankful .
