McAfee Icons Problem
In the following picture look at the four identical icons to the left, they keep coming up every minute or so, the only way to make them go away is to hover my mouse over them.
When I hover the mouse over them they disappear before i can click on them.
When I looked under toolbar properties then customize to see the icons names it was listed as "canceling".
Thank you for any help.
5 answers Last reply Best Answer
More about mcafee icons problem
  1. Take McAfee out of your computer, and install a professional security system.
    This will solve the problems, current and future.
  2. I would but this is my work issued laptop and I cannot install new software.
  3. Best answer
    Without administrator rights, there's not much you can do. You can take it to work and let the IT department fix it.
    It looks like McAfee is failing on a process. It can be reinstalled, or replaced by a better software. Either way, you'll need admin rights to do it.
  4. Thanks thats what I ended up doing and they fixed it.
    nBest answer selected by byrnedj.
  5. You're welcome. Thanks for the update and the vote. :)
Security McAfee Mice Icons Windows XP
